Ohio e-check info. - LS1TECH
Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Ohio e-check info.
Thread Tools Search this Thread
Old 12-01-2007, 11:37 PM   #1
Default Ohio e-check info.
Hoping for someone to that's been there to give me some info on what will fail a car for Ohio e-check. I'm looking at putting quite a bit of money into the car, and I don't want to have to deal with the hassel of it failing. Also, I'm aware of the collectors plate stuff for firebirds to get around e-check. Will reprogramming the PCM to eliminate EGR or AIR system codes then removing the O2 and AIR systems make the car fail the OBD2 test? How about reprogramming to eliminate skip shift?
Mike44138 is offline   Reply With Quote
Old 12-02-2007, 09:31 AM   #2
gillbot's Avatar
You can tune it to pass but they will do a visual inspection so you need cats. Mine passed with my TR230 cam, all emission components removed and headers, I just used a catted Y pipe.
If you search, there are alot of threads that cover what is needed to make it pass. Just search for OBDII and echeck, you should find something.
gillbot is offline   Reply With Quote
Old 12-02-2007, 02:12 PM   #3
BRAKE's Avatar
If you have another car in your name you can always get collectors plates and by pass e check all together
OR..
you can have cats on (but they can be hollowed out, as long as the inspector physically sees them) and make sure you have no check engine lights then you will pass. All the obd2 cars are just plugged into a computer to see if theres any ses lights, no sniffer, unless for some reason the computers wont sync up.
Your going to have to have the car tuned with HP Tuners or LS1 Edit to do it properly.
BRAKE is offline   Reply With Quote
Old 12-07-2007, 08:06 AM   #4
gillbot's Avatar
Quote:
OR..
Not really. You need to have the codes set to X instead of no report, otherwise it will fail as not ready even if your light isn't on.
Old 12-07-2007, 10:03 AM   #5
That's what I figured, I was just wondering if tuning the codes out would mess up the readyness indicators, or if they did some type of check for a tune that would force the car onto the dyno. Thanks for the info guys.
Old 12-08-2007, 10:18 PM   #6
00silverGTP's Avatar
they are checking cars in ohio? never had one checked.............
00silverGTP is offline   Reply With Quote
Old 12-09-2007, 02:09 PM   #7
gillbot's Avatar
They used to have it in the Cleveland, Cincy and Dayton area. Now they only have it in the Cleveland area.
Old 12-09-2007, 05:29 PM   #8
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm glad Scioto County doesn't do E-checks
Z28/2002 is offline   Reply With Quote
Old 12-15-2007, 12:32 AM   #9
SweeTbone's Avatar
They don't do it here, but I'm fixing to get some Collector Plates so when/if they do I'm cool. I initially wasn't getting them to get around E-check, I just wanted them, but E-check could expand this way and I don't want to get caught slipping.
SweeTbone is offline   Reply With Quote
Old 01-05-2017, 01:21 PM   #10
ldjfsdlf
SalG is offline   Reply With Quote
Old 02-13-2017, 04:03 PM   #11
You can get Collector plates. I am getting them for my 01 Trans am. I am in an E check county. All you need to do is call Columbus or go to your local BMV. They will point you in the right direction.
hooley is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Ohio E-check issue. Need help! Bad324 Midwestern Members 16 02-02-2017 11:35 AM
Some help with E-check?---Northern Ohio Guys Come In! Ruedy4 Midwestern Members 8 03-17-2010 01:39 PM
Ohio E-Check? SSprayn Midwestern Members 15 06-25-2007 06:54 PM
Anyone know anything about OHIO Collector Plates? BlackDuk98 General LSX Automobile Discussion 2 10-22-2006 07:47 PM
ohio/e-check/aftermarket exhaust kozak Midwestern Members 14 06-17-2006 10:07 PM
Tags
beating, brake, check, codes, cuyahoga, echeck, fail, falls, light, maf, needed, nos, ohi, ohio, part, pass
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
