help please.. car is messed up
alright well when i am driving the car normal, it is fine, but when i get on it, it bogs out all stupid and wants to die out. like to day i hoped on the skyway and when i stomped on it it moved out for like 2 seconds until the nose dropped and it started to bog out. what can this be?? please help thanks
-Matt
-Matt
It could be a fuel pump that is going bad, or the 02's had gone bad, or the cats are clogged, etc. Is the SES light on? If it is, have the car scanned for the code(s). Bob
is there any tune on it? sounds like it needs more fuel at WOT... may need the timing advanced a bit... depends on whats done to it.. and like he said above... could be O2's.
yea cuz i dont have any cats and i never had gotton the o2 sims so when i scan the ses light it reads that all my 02 sensors are bad. so do you think if i by new o2s and the sims then it will be good again. thanks for the help.
-Matt
-Matt
Check all the major sensors. The map sensor on the back of the intake has some vaccum lines to it that like to release themselves all the time.... At WOT it can bog out due to O2s being way off.... MAF sensor can sometimes make the car do funny things like no matter how far the gas is pressed it will never go past 45 or so... My guess is one of those... If you have a K&N filter or similar oil style filter may want to clean off the MAF with a little cleaner and be sure not to over oil it.....
thanks man, the other day i checked it and it was the maf sensor. my buddy told me to check that before i spend a **** load of money on pointless ****. thanks for looking out tho
