HELP:puttin cam in and need a lil help
ok well i just ordered my cam, and it is the hotcam kit. so this comes with the cam and springs, and i think some other goodies, but i do know that i will need new pushrods. now can i use the stock length or do i need a different lenght pushrod? this is my first ls1 that im doing a cam in so if you guys can lead me in ther right direction and let me know what il need to buy il greatly appreciate it, and if someone is down to help me hows some beer and a lil cash sound? let me know by shootin me a PM, thanks, Matt
LS1TECH Sponsor
pushrods
Matt,
Just wanted to let you know the stock length 7.400 pushrods work fine but I would suggest to go ahead and buy a hardened rod like a manley. PM me back and i can get you some prices...Thanks hope this will help ya....
Stock length should be fine, unless your changing to a diferent ratio rocker... Like going from 1.7 to 1.8... I would def do the hardened rod, and they can be had from multiple sponsors for a decent price...
If you need any more info, I just got done with this swap last winter and can give ya any input needed. Let me know.
Could also give you a hand... Depending on the when and where. Doing it yourself isnt bad, but there are a few things that really do help if your leaving the heads on....
here's a link that a lot of people have used in case u havn't seen it. where in chitown r u located?
http://www.ls1howto.com/index.php?article=23
