421 Solid Roller Dyno Vid 608 RWHP
Old 11-22-2008, 05:48 PM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
Default 421 Solid Roller Dyno Vid 608 RWHP
Finally got to post up the dyno videos from the car. The thing drives great and runs on pump gas.
I'm not telling you it drives like stock, but for what it is it's not bad.
2001 Trans-Am WS6 M6
421 Iron Block
12.5:1
ETP 255’s
Rapid Motorsports Dominator Solid Roller Cam
Jesel J2K 1.7’s
Beck Sheet Metal Intake
Fast 90mm
Pump Gas
Kooks 1 7/8 x 2 x 3 ½ stepped headers with off road pipes
Kooks Y-pipe
Mufflex 4” catback
Textralia Twin Disk
D&D Viper Spec T-56
Denneys nitrous shaft
Moser 12 bolt, 4.11 gears
608rwhp 496rwtq
The rattling you hear is the broken exhaust cutout, the shaft was broken and rattling like crazy
Dyno 1
Dyno 2
Old 11-22-2008, 05:56 PM
'Trust''s Avatar
Nice numbers!! TQ seems a lil low though?
Old 11-22-2008, 05:57 PM
bad95killer's Avatar
Very impressive numbers man....Congrats
Do you have the Graph ?!
peace
Old 11-22-2008, 05:58 PM
Redlinez's Avatar
Frickin awesome man!!!!!
Old 11-22-2008, 06:04 PM
03 BUSA's Avatar
It's about time. Need to teach em how to strap that thing down properly. Would like to hear more idle but still badass.
Old 11-22-2008, 06:17 PM
antz01ta's Avatar
now that i got the computer figured out i can get some idle clips.
give me a day or 2.
Old 11-22-2008, 06:19 PM
antz01ta's Avatar
Old 11-22-2008, 06:41 PM
03 BUSA's Avatar
give me a day or 2.
Thanks man.
Old 11-23-2008, 09:46 AM
KCFormula's Avatar
Thats the beck intake. I'll have to get a graph of mine up and you can see there is a huge difference in tq. but the trade off is peak hp.
What are the specs on that cam? It sounds pretty tame, or is it the catback?
Old 11-23-2008, 01:35 PM
03 BUSA's Avatar
[QUOTE=KCFormula;10532363]Thats the beck intake. I'll have to get a graph of mine up and you can see there is a huge difference in tq. but the trade off is peak hp.
QUOTE]
It is also the 4" exhaust with big stepped headers but like you said the trade off is peak hp which is what I think he wanted for his purposes. I also thought it sounded very tame down low, that is why I asked for a separate idle outside vid.
Old 11-24-2008, 01:31 AM
blackbird-TA's Avatar
pretty mean set up what i would like to know is every body i talk to a bout cams when i say i want to go with a solid roller build up every body say's it will not last ???? and will give me a bunch of problems what do's a solid roller cam do so bad i think the sound and hp gains would be way.. better
i would love to see hear some idle/rev clips and drive by's @ WOT.....
Old 11-24-2008, 05:18 AM
antz01ta's Avatar
A solid roller is fine as long as you keep an eye on valve clearance and pull a spring once in a while to check pressures.
I have the videos of idle and a rev, I'll post them up later today, not gonna see a drive by, it snowed the other day and there is salt on the road, the car is in the garage for the winter.
Old 11-24-2008, 05:21 AM
antz01ta's Avatar
it's a 260/266 .700/.700 112
as said above it has 1 7/8 - 2" step headers and a Beck intake so the torque is low but hp stays flat all the way to 7500 rpm.
with that said until the car is in 3rd gear you can't put the throttle on the floor unless you want to have the tires go up in smoke, more torque down low would be usless anyway for the street.
Old 11-24-2008, 11:57 AM
03 BUSA's Avatar
Looking forward to it. Very cool. Thanks man.
Old 11-24-2008, 06:36 PM
antz01ta's Avatar
Smile
Here you go guys, video as requested and i also threw in a couple pictures.
Idle Clip
My favorite part of the Rev clip is how slow the stock tach is.
Quick Rev
Old 11-24-2008, 06:48 PM
03 BUSA's Avatar
That's thing looks and sounds great. That is much better than the previous vids. Great job man, looks very proffessional.
Old 11-24-2008, 06:52 PM
antz01ta's Avatar
Thanks, I have a lot of time into it and I think it came out decent.
By your sig it looks like you will have a great setup too, be sure to post it up when you get it done.
Old 11-24-2008, 07:01 PM
03 BUSA's Avatar
Will do. Not sure on intake just yet and the cam will be slightly smaller with mid 700's lift on a 110 and 1.8 rockers. Same compression right around 12.4 or so. Should be done in the middle of winter. Yay! I will def post up when done. Whose v.covers are those? They look really good on that setup.
Old 11-24-2008, 07:07 PM
master of the "jack"stand
ChevyWeatherman's Avatar
its the ****
Old 11-24-2008, 07:08 PM
antz01ta's Avatar
Thanks
They are Moroso
Quick Reply: 421 Solid Roller Dyno Vid 608 RWHP
