Insane 1400hp Tube chassis EVO Drag car
Old 11-23-2009, 06:31 AM
Blue72's Avatar
Default Insane 1400hp Tube chassis EVO Drag car
Has anyone else seen this thing. It Definately has the potential to be a 7 second car.
http://www.sportsnimports.com/board/...g-monster.html
Old 11-23-2009, 02:34 PM
DiscerningZ32's Avatar
I certainly hope it gets into the 7's...
That thing should be light as hell.
I think they should have given in and gone RWD with it though since they went to a tube chassis in all honesty.
Old 11-25-2009, 03:28 PM
Blue72's Avatar
I agree. However there are a few 1G's out there back halfed with 4 links,tube up front,still running the AWD drivetrain. The ones I've seen are still in the process of being built so I don't know how they perform. However there is a tube chassis,tubbed AWD Suburu that runs in the NHRA Sport Compact series. They run larger slicks in the back than in the front. It seems to work well. They made some good numbers when I saw it run.
Oh,also I'm not sure if the EVO makes 1400hp or if thats just the maximum recommended hp limit for the motor. I know the same company (Magnus) builds the motors in Brent Rau's 1,300+WHP 6 second tube chassis RWD Eclipse. So it is very possible it does make 1,400hp.
Old 11-25-2009, 10:20 PM
DREAMZ28's Avatar
Looks like a damn serious build. If its putting out the said power i would expect 8.0's-7.8's.
Those imports can get it done if you have the bank to do so.
Old 11-25-2009, 10:34 PM
Kleeborp the Moderator™
MeentSS02's Avatar
That has about as much in common with an Evo as my Camaro (kinda kidding, kinda not), but it is impressive none-the-less.
Old 11-26-2009, 04:11 PM
02TransAm/Batmobile's Avatar
I believe any car can get it done if you have the funds.
Old 11-27-2009, 10:25 PM
Green3spd's Avatar
.........................Ill run it...
Old 11-28-2009, 07:03 AM
MonmouthCtyLS7's Avatar
That thing looks stock.
Old 11-28-2009, 08:43 AM
sabastian458's Avatar
That thing better run in the 7's on Methanol, there are stock bodied Evo's running in the low 9's and mid 8's already on race gas.
Old 11-28-2009, 01:20 PM
Apex_632's Avatar
And then you had John Sheperd's stock unibody awd talon running 7.70's on a methanol set up. So I would hope this tube chassis car could at least match that.
Old 11-28-2009, 04:41 PM
master of the "jack"stand
ChevyWeatherman's Avatar
That's one sweet machine.
Old 12-02-2009, 11:04 AM
BanditTA's Avatar
Cool car but he should remove "DC electronics custom Mil spec wiring loom " from the description
Old 12-10-2009, 09:33 AM
1slowM6's Avatar
man that thing is ridiculous looking
Quick Reply: Insane 1400hp Tube chassis EVO Drag car
