My Trans Am, A Tank & Some 315's
Old 02-29-2012, 10:28 PM
HibachiZ28's Avatar
Talking My Trans Am, A Tank & Some 315's
Nothing amazing, just two shots from this past week:
Outside of Conowingo, MD:
In West Chester, PA - showin' off my 315/35/R17 Nitto's - car is dirty as hell btw at this point:
Also, my new Centric/Powerslot/StopTech slotted rotors & pads should be here within 2-3 weeks (backorder). Can't wait.
Old 02-29-2012, 10:33 PM
JUSTINSWS6's Avatar
You say hi to the margera's?
Old 02-29-2012, 10:40 PM
HibachiZ28's Avatar
https://ls1tech.com/forums/multimedi...my-camaro.html
Old 02-29-2012, 11:14 PM
'00_Z's Avatar
Looks pretty damn sick from the rear!
Old 02-29-2012, 11:16 PM
autogeek23's Avatar
Wow. I want 315's so bad now. That looks really aggressive
Old 03-01-2012, 12:42 AM
TruBloodTransAm's Avatar
How did you get your 315's to fit? BFH mod?
Car looks great, but fix your faded rear filler panel.
Old 03-01-2012, 01:12 AM
omarrakeen's Avatar
agreed. that is one sweet car..and btw you might wanna lower the sharpness on your camera just a bit.
Old 03-01-2012, 07:59 AM
HibachiZ28's Avatar
Thanks all. The filler panel will be fixed, among other things, as the warm months slowly approach. I have a list of OE pieces that I'm fixing:
-Pass side mirror
-Driver & pass side door scrubbers
-Front bumper cover respray
-Rear filler panel decals
-Rear lower bumper respray (Scraped bad, I photoshopped it here)
And so on.
It is so crazy the difference I have with grip on these versus the 245's I had on here when I got the car. My handling improved drastically with the new, wider wheels too (17x9.5" up front and 17x11" in the rear). I highly recommend upgrading if you haven't already! Regarding fitment, BFH mod was not required. However, I will be rolling the fenders with a Louisville Slugger as it does rub sometimes on deeper highway bumps, and when cornering pretty hard:
http://forums.nasioc.com/forums/show....php?t=1777067
Old 03-01-2012, 09:19 PM
JUSTINSWS6's Avatar
I have 315 toyo drag radials on a oe c6z06 rim did bfh and cut bump stops flush with the body(because when it was on a lift the rim would get caught). They dont rub or and thing. It picks the front up so it will not rub and have had it sideways around corners. I didnt roll my fenders and dont advose any one to do so.
Old 03-02-2012, 08:19 AM
HibachiZ28's Avatar
did bfh ... I didnt roll my fenders and dont advose any one to do so.
How come? BFH & rolling your fenders are basically the same thing. One is usually really clean, where the other is a bit more of a "hack" job (but still works fine).
Old 03-02-2012, 07:17 PM
Kyles03's Avatar
Looks good!
Old 03-02-2012, 07:19 PM
JUSTINSWS6's Avatar
Bfh is fine but when you roll the fender the paint can crack and wont look that good. You should be able to get by with out rolling the fenders.
Old 03-02-2012, 07:59 PM
Guitar's Avatar
There is absolutely nothing wrong with rolling your fenders and it is completely necessary in some situations. If you do it right your paint will be absolutely fine.
Old 03-02-2012, 08:29 PM
HibachiZ28's Avatar
Yep, if you do it right it's much better than a BFH. You need to use a heat gun and tape appropriately and you're good to go.
Old 03-04-2012, 09:19 AM
Grn4fbody's Avatar
Looks good
Quick Reply: My Trans Am, A Tank & Some 315's
