My Turbo Camaro at the drag strip.
Old 04-01-2012, 12:13 PM
forgedlt4's Avatar
Default My Turbo Camaro at the drag strip.
I learned that i need to practice more.
I only tried 3 times, and I failed all tree times.
I was also only on 7 lbs of boost, and i had planned on turning it up to 12, but i never got a good launch, so i never did.
I was hitting rev limiter in 4th gear anyway, so i need so swap gears from my 4.11s to a 3.55
this was like a 12.3 at 128mph lol
http://www.youtube.com/watch?v=Js0b3UigvgA
and this was a measly 11.7 at 129 mph
http://www.youtube.com/watch?v=5xyhB_1_Sk8
Neither runs I am proud of, but not a bad MPH for an LT1 on 7 lbs I guess.
Old 04-01-2012, 12:26 PM
forgedlt4's Avatar
Also, a hood will eventually cover that pipe up. just gotta find the time.
Old 04-01-2012, 02:02 PM
Spd-Kilz's Avatar
That car is so quiet! Definitely has some good potential if you can launch it well.
What's done to it?
And do you really need to drop it down to 3.55s? You're just hitting the limiter as you cross the 1320...
Old 04-01-2012, 02:52 PM
bizerk1's Avatar
practice at a place near your house, long quiet road with no1 really around!!!
Old 04-01-2012, 05:25 PM
forgedlt4's Avatar
What's done to it?
it's a 383 lt1, home lt4 ported heads, single plane intake, blow through, gt42 turbo, E85.
the 129 mph run was on the limiter a little more.
all runs we're on low boost (7lbs). I am turning it up soon to 12, then even higher.
Old 04-02-2012, 07:26 PM
LSXFORMULA99's Avatar
yeah man i was there when you were running lol...car is so quiet. When you get it figured out mid 10s should be easy
Old 04-02-2012, 08:35 PM
MillsMotorvation's Avatar
I like it, I hope I can MPH like that. So what killing your launch?
Old 04-02-2012, 09:40 PM
forgedlt4's Avatar
not enough practice. one run it bogged, and one run it spun.
ill get it down eventually.
Old 04-03-2012, 12:50 PM
Kregkenny's Avatar
Those are great. Keep it going man
Old 04-03-2012, 12:56 PM
HRHohio's Avatar
Beautiful Car! I like it!
Old 04-03-2012, 07:42 PM
doublea87's Avatar
i got i video on my phone too, just need to figure out how to load it lol. cant wait till you and Alan go at it again! that e85 smells so nice
Old 04-03-2012, 08:51 PM
adamantium's Avatar
Why not just try going up in tire size?
Old 04-03-2012, 09:14 PM
forgedlt4's Avatar
Im already runnning a 28x12.50
Old 04-04-2012, 01:27 PM
RealQuick's Avatar
nice man! car sounds great.
Old 04-04-2012, 02:13 PM
PhantomR/T's Avatar
keep praticing. YOu'll get it!
Old 04-05-2012, 06:46 AM
forgedlt4's Avatar
thanks guys!
whenever I get some time, I'll take it back.
I'm going to use the two step this time, and do a better burnout.
Old 04-05-2012, 02:29 PM
SStolen's Avatar
Think a Line Lock would help for a better/longer burnout?
Are you running full exhaust? I would think that would be really bad for back pressure, especially with a 383. Depends on the size of your turbo and downpipe size. It looks like and sonds quiet enough to be a magnaflow. I run the same catback except I have a cutout that dumps about 5ft after the turbo in front of the driver seat. Let that motor breath. An electric cutout is cheap and you will probably pick up 50rwhp, no joke.
What kind of rear are you on?
What turbo/kit are you runing? Did you dyno it? Thats great mph for 7lbs.
Post some picks.
Old 04-05-2012, 02:32 PM
xRelapse13's Avatar
Nice set up, what kinda numbers do you put down?
Old 04-05-2012, 03:40 PM
forgedlt4's Avatar
Post some picks.
Here is a pic of when it was in work
thats 4.5 inch piping on the "down pipe" and it splits into dual 3 inch mandrel bent piping over the axle on each side exhaust. dynomax bullet mufflers.
this is how it sits now, it needs some attention.
As far as the dyno, i havent re-dynoed since i changed some things. something was wrong on this dyno run. as you can see, it flat lines at 4800 rpms.
i have since changed the timing by 1 deg, and adjusted fuel AFR to 11.5:1 at WOT.
Old 04-05-2012, 06:31 PM
SS-ROB's Avatar
What RPM are you shifting at? Nice setup
