Livernois 9-Sec ZL1 Info and Video - LS1TECH
Thread Tools Search this Thread
Old 05-12-2012, 12:55 AM   #1
LS1TECH, Trucks, Modmotor Sponsor
LivernoisMotorsports's Avatar
Default Livernois 9-Sec ZL1 Info and Video
See our website for our ZL1 specific packages. We can also build a package to fit your needs.
Specs:
Delivered by Rodger’s Chevrolet 4-27-12 (yes, we’ve only had it 2 weeks!)
2012 ZL1 Auto trans - Full weight with exception of wheels/tires
100% stock suspension
Stock trans w/ Livernois specific trans calibration
Stock catback
4,295 lbs. with driver
240 Miles
Mods:
Livernois Motorsports In-House CNC LSA Cylinder Heads
Livernois Motorsports Stage 2C High Lift Camshaft
Livernois Motorsports LSA Head Studs (Available soon)
Livernois Motorsports Exclusive Heat Exchanger (Available soon)
Livernois Motorsports Solid Supercharger Coupler
Livernois Motorsports Supercharger Pulley
Livernois Motorsports Exclusive Steel Idler Relocation Bracket w/ Metco Pulleys (Available soon)
Livernois Motorsports Spec’d Injectors
Livernois Motorsports Dual Fuel Pump Upgrade
Precision Industries Converter Built to Livernois Specs
Metco Oversize Crank Pulley Ring
Innovators West Oversize Balancer
Rotofab/Livernois Cold Air Intake (Available soon)
Stainless Works Longtube Headers & Connection Pipe
Hardened Pushrods
NGK TR6 Spark Plugs
160 Degree T-Stat
GM 90mm Throttle Body
Bogart 17” Wheels w/ Slicks & Skinnies
Livernois Motorsports Dyno Tune
Dyno Results Stock:
476 RWHP / 476 RWTQ
The best pass 100% stock with 110 miles on the odometer was 12.41 @ 115.9 mph. It was traction limited and the track was extremely busy, so I didn’t get a good feel for the car and how to launch it.
Dyno Results Modified:
707 RWHP / 680 RWTQ (Roughly 850 crank HP)
Note: Our tuner Dan Millen was at the track with me all day logging each pass and getting more and more aggressive after each pass, so I’m sure the power was quite a bit higher than what we saw on the dyno.
I wouldn’t hesitate to daily drive the ZL1 with these mods (minus the wheels/tires).
I do plan on driving the car to Rodger’s Chevrolet for their show/open house tomorrow, then back to Milan on the stock wheels and Mickey Thompson ET Street Radials to see what it will run on 20’s.
The first pass off the trailer today, the car went 10.14 @ 138 MPH. Many of my launches were from just above idle and it was like a bracket car with several 10.0X-10.1X passes @ 138-141 MPH, and FINALLY on the last pass 9.87 @ 142 MPH!! Dan got pretty aggressive with the tune and told me to leave as hard as I could off the converter. We WERE going 9’s on this pass! I did the burnout, staged, then focused… not worrying about my reaction time (it was horrible as you can see), put it on the converter until it felt like it was going to roll forward and let it rip. I knew at the end of the track it was a good pass when I saw 145 mph on the heads up display.
We are also currently working with PSI Superchargers to improve the factory blower. Dan runs a PSI screw blower on his 3-Second 200+ MPH 1/8 mile race car.
Huge Thanks to:
GM for building an awesome car, Rodger’s Chevrolet, Milan Dragway for the great track, Innovators West, Metco, Mickey Thompson Tires, Precision Industries, Rotofab, Stainless Works… and the technicians at Livernois Motorsports!!!!!!
vid
Thank you
Regards,
Rick LeBlanc
LivernoisMotorsports is offline   Reply With Quote
Old 05-12-2012, 01:41 AM   #2
ThumperNC24's Avatar
Not bad for 2 weeks. haha
That thing is heavy as **** but at least she can make some serious power.
With the tune and everything where it is, would you have any worries about longevity and reliability down the road?
ThumperNC24 is offline   Reply With Quote
Old 05-12-2012, 11:18 AM   #3
navyblueSS's Avatar
Very impressive!
navyblueSS is offline   Reply With Quote
Old 05-12-2012, 02:06 PM   #4
Brought out of retirement Super Moderator
Reckless's Avatar
Stock converter too? Nice job guys! Man that thing is heavy.
Reckless is offline   Reply With Quote
Old 05-12-2012, 10:28 PM   #5
Quote:
No, it has a custom PI unit according to the mod list.
MikeG is offline   Reply With Quote
Old 05-13-2012, 10:41 AM   #6
Thanks for the replies!
With the tune that made 707 RWHP, no worries. It ran bottom tens with that tune and pump gas. With the tune it had for the 9-second pass.... it's already been removed and back to the off the dyno tune. We were determined to go 9's first and the tune was "on murder" and it was on race gas. It was going 9's running or not when done.. Lol
-Rick
Old 05-21-2012, 09:55 AM   #7
Does it use the TVS2300 OR 1900?
427LS7HCI is offline   Reply With Quote
Old 05-21-2012, 04:27 PM   #8
I asked the same question in a different thread and he said that nobody makes a bigger blower for it yet so their refining the stock 1.9 until a bigger unit comes out. I can only assume that there maybe a packaging issue with the hood,cowl, or accessory drive.
firebird99 is offline   Reply With Quote
Old 05-21-2012, 04:40 PM   #9
02sleeperz28's Avatar
Nice!
02sleeperz28 is offline   Reply With Quote
Old 05-21-2012, 04:45 PM   #10
Captain Double Post
Nice the big question will be are you guys going to get your hands on a gt500, i would like to see how much work it takes for a 9 second pass in one, there going to get compared through a microscope modded n stock
BOBS99SS is offline   Reply With Quote
Old 05-22-2012, 02:25 AM   #11
It won't take as much based on what we've already seen but at the same time I THINK (could be wrong) that the GT500 has a really small pulley and doesn't have alot of room to go other then smaller crank pullies.
Old 05-22-2012, 09:13 PM   #12
Administrator
unit213's Avatar
Quote:
Are you sure you know what you're talking about? Smaller crank pulley?
unit213 is offline   Reply With Quote
Old 05-25-2012, 01:39 PM   #13
Oh I'm sorry I meant "A BIGGER PULLEY" thanks for pointing that out and trying to make it out like i know nothing because I made a mistake.
Old 05-30-2012, 07:13 AM   #14
nick122590's Avatar
Quote:
pulley, tune, slicks....
nick122590 is offline   Reply With Quote
Tags
2012, 9s, 9sec, camaro, hp, list, livernois, ls1tech, mod, mods, motorsports, pulley, sec, tb, zl1
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
