Maggied/Monaro'd GTO Drag Strip
Drivetrain:
Stock bottom end
243 heads w/comp cams trunion upgrade
Morel linked lifters
Predator cam 224/230@114lsa
Magnuson MP112
Pulley boys 2.7" pulley
Moroso coolant tank for blower
Cobra heat exchanger w/custom mounts
Svede OTRCAI with custom adapter
Hendrix Engineering blower snout, tbody, and radiator
Kooks 1 7/8" longtubes catless mids
Magnaflow 3" exhaust
Lingenfelter fuel pump
NGK AFX wideband
SD tuned at CSP in West Chester 516RWHP
Wilwood 13" front 12.19" rear brake package
Lovells Eliminator kit 20mm drop with a handful of poly bushings
Hendrix Engineering street slayer clutch w/ Fidanza flywheel
MGW-P short shifter
GForce Engineering 3.5" aluminum driveshaft with billet yoke
GForce Engineering inner stubs and anit wheel hop half shafts
Harrop diff cover
Running on a 275-40-17 Mickey Thompson ET street radial
