Project: CODERED Colorado
Just noticed I never made a build thread over here
Here is the build thread for my 2004 Chevy Colorado ZQ8 Crewcab which I purchased back in Dec 04, with 200 miles on it used.
2004 ZQ8 3.5 Auto Colorado Crewcab
All stock
All stock
Goodmark 2 inch Cowl Hood added
Xenon Side Skirts added
Street Scene Fog Lights added
factory flares were removed for the time being due to the side skirts
Truck all painted up
Added AEM intake
Added Magnaflow exhaust
Installed clear corner headlight and parking/turnsignal lights
audio install
JL Stealth Box I got for half the cost of new and a amp I had laying around
installed Street Scene Stainless Grill
Added AEM intake
audio install
American Racing RTS 20's
Drop number 1
Belltech 2inch Ball Joint Drop
Belltech 3inch Leaf Spring Drop
My friend Josh helping out
has a little bit of a rake
Drop number 1
Drop Number 2
well with the first setup I was rubbing like crazy on bumps
So I switched the factory ZQ8 springs out with Belltech 1inch drop springs so I went back up 1/2 inch in the front
Painted front caliper setup 2 tone
Installed all red 3rd brake light and TYC LED tails
Added my flush bed cover and the street scene spoiler
New stainless steel gauges also modified the needles to red
bed cover and spoiler painted
Clean cut creations crossmember still needs to be installed
Drop Number 3
Belltech Coilover setup for the front Also have a set of 1 inch blocks for the rear that I havent put on yet
pics from the coil over install
well got them on the passenger strut gave me issues when taking it out.
picked up a set of 18 inch factory colorado xtreme wheels for the winter time and track
painted the wheels flat black
then finally got my center caps
Also added Street Scene mirrors
Drop Number 3
Picked up a set of Silverado SS wheels
had a friend bore them out
test fitted ;-)
added rubber :-D
got some new tires bought them used with 1k-1500 miles on them for $300
old 245/35/20
new 255/35/20
old currently on the wheels
new against old
New stacked up till I decide to swap them on
test fitted ;-)
added rubber :-D
old 245/35/20
new 255/35/20
new against old
So awhile back I picked up a canyon shell from Paul that he already cut out
Also picked up a SS grill for it
I got the grill and my bumper as well as the colorado grills powder coated
meanwhile I was gettign the bumper fixed and repainted and getting the grill shell painted also
for ***** and giggles I threw the decoma inspired grill on while waiting
pieces all painted
installed
pieces all painted
installed
hmmm what Did I pick up??
L33 5.3 V8 Out of a 06 Silverado. Has 22k miles on it. All aluminum block and heads
the bad parts
need a new pulley no biggie
smashed oil filter umm ok
oh the damn cracked oil pan (they only took 50 bucks off for that grrr)
the bad parts
and before I left for Israel I blew a tire
However bad news I did hit something and it shot a hole through my inner fender and dented the bedside from inside
Picked up some new tires
LH8 oil pan for the V8
Painted behind my grill
I'll have a few other items coming when I get back from Israel
One thing I need to fix when I get back is my exhaust
Still need to paint the heads, valve covers, brackets, water pump, pulleys, etc....
Not sure how I'll do the fast intake
Swapped out the oil pickup since I have to use a LH8 oil pan (colorado/canyon/h3) since the silverado one won't work, and the oil pickup was too long so I had to use a LH8 one. However I did get a new windage tray but I saw no need to swap it out.
LH8 pan, it will be staying the cast aluminum color
some painting
the headers are just temp until i get them stripped and coated
AC compressor bracket still need a AC compressor lol
So some new parts
Trailblazer Peddle
Computers
Fast fuel rails
now I'm actually having a issue with a couple of the injectors not wanting to seat right in the FAST intake, so I need to work on that.
So some new parts
Trailblazer Peddle
Computers
Fast fuel rails
