Not sure on raceweight...should be pretty close to stock. THe only thing out of the car is AC and the spare tire. I bought the car this year with most of the work already done and I've been tuning it myself.
I plan on going back sometime next week if the weather holds up. If I don't make it next week, I'd like to go to the last No ET event in the beginning of November.
Yes being an auto helps you a lot! Try running the stock rear with a M6, 4.10 gears, 125 shot, and drag radials....I know I'm on borrowed time lol
Yea, I used to have a 99 LS1 that was heads/cam/ 6 speed and I broke the 10 bolt as soon as I put a good clutch in the car. I also hurt a Ford 9 inch leaving at 6500 rpm lol
You had to be leaving pretty damn hard at your power level to hurt that 9 in. Lol
It was in the description of the video on youtube. This pass was 11.86@114.6 on a 1.65 60'. Still working on the tune, the car was lean on this pass(13.1 AFR)
Ah not bad! I watched the embedded video here, so I couldn't see the description. What RPM do you go through the traps at with the 3.73 and what size tire? I recall my MS cam liking a lot of RPM. I had 4.10s in mine.
It's a 28" MT ET Street. I'm crossing the traps at just under 6k.
If you have no plans to spray it I'd step up to a 4.10 gear, or down to a 26" tire. You're leaving a lot on the table with your current setup. My car was going through the traps at 7100 with the MS4.
