Looking for a video that shows a 3800 stall cruising around town.
Old 07-17-2006, 03:15 PM
TransAm_00's Avatar
Default Looking for a video that shows a 3800 stall cruising around town.
...........Title sums it up.
Old 07-17-2006, 03:58 PM
john3daly's Avatar
This is a 3600 stall, won't be much difference. If you're debating, DO IT! I'd have went 4k+ if I could do it all over. I'm going with a 4800 in my new TH400.
http://www.we-todd-did-racing.com/we...EzZGZkMzF5NTQx
Old 07-17-2006, 04:07 PM
TransAm_00's Avatar
Cool,, thanks... Anyone else???? Maybe something like a stop and go from a couple of lights. So I take it that having a stall doesn't just effect a dead stop take off, but also shifting as well????
Old 07-17-2006, 04:12 PM
john3daly's Avatar
You're going to get used to the stall in a matter of minutes. After driving mine for 15 minutes it felt stock......as long as you get a lockup converter, which I'm sure you will. Do they even make unlocked verters for 4l60e's? Anyway, just get it man, you'll love it. You don't have to rev it til the stall rating for the car to move. It'll begin to move just a few hundred rpms above stock settings. The rating is only for if you "flash" the converter, meaning you nail the gas. And even that can be off, it varies by how much power you make.
Old 07-17-2006, 04:14 PM
TransAm_00's Avatar
I have a SLP lid and LM, ported TB, spiro pros, ngks.
What converter would you recomend. It is a daily driver. Also, how much wear and tear does a stall do to the car.
Old 07-17-2006, 04:17 PM
john3daly's Avatar
I ran a Vigilante 3600 and would recommend going to a 4k or so. The car was my daily driver at the time and I noticed little difference in daily driving. However, it performed amazingly well at the track. I have a high tolerance for "streetability" but I don't see any reason whatsoever a stall wouldn't be streetable. Especially one under 4k rpms.
Old 07-17-2006, 04:20 PM
TransAm_00's Avatar
Cool,, thanks for the info.
Old 07-17-2006, 04:22 PM
john3daly's Avatar
No problem. I know I had a million questions before I got my first converter. Good luck man!
Old 07-17-2006, 11:44 PM
camaro98z28's Avatar
It will be fine. I run one and I just had to get used to it but it works great and is bad *** when it locks up and your gone. DO IT!
