My tsp TRQ v3 sound clip
get that thing tuned and idle up around 950rpm's With the rpm's that low it sounds like your tring to make it lope. The cams going to sound even beter st 950 rpms. Plus it will save the 02's and mpg. Sounds good other then that
111 lsa
just got back from the track made one pass
60..1.77
1/4.....12.22
mph....111
so not too bad hit the rev in first bad. soft launch and running out fuel the hole run (92% injector duty cycle)
i will post up a vid
60..1.77
1/4.....12.22
mph....111
Sounds absolutely sick. You said your not into number but have you had it tuned yet? You would pick up some nice power from that whether you care about numbers not it would give you much more of a chance for mid 11s. Ive been looking at that cam so if you do put it on the dyno be sure to post the numbers!!
