99 camaro A/C works but air coming out is warm? - LS1TECH
Thread Tools Search this Thread
Old 09-16-2009, 12:16 AM   #1
Default 99 camaro A/C works but air coming out is warm?
I can hear compressor coming on and lines are getting cold under hood but air coming out of the vents is still warm.. Thought it maybe the selector switch from hot to cold, but if i turn it to hot the air gets warmer.. any idea's what i need to check??
crowdpleazer is offline   Reply With Quote
Old 09-16-2009, 12:18 AM   #2
oliphant14's Avatar
Quote:
you have to get it recharged man. freon or however you spell it it is kinda exspensive though. thats all you need
oliphant14 is offline   Reply With Quote
Old 09-16-2009, 01:01 AM   #3
I just had to do this on the viper. It was loosing the coolant during the winter and need to be recharged every spring. It turned out to be a o ring on the compressor. $.50 oring and a recharge and its been all good for years.
So I would dye test it to find were its leaking from to keep from recharging it.
SchuttsR1 is offline   Reply With Quote
Old 09-16-2009, 02:30 PM   #4
bamalt1's Avatar
Freon isn't expensive it's like 10 or 20 bucks
bamalt1 is offline   Reply With Quote
Old 09-16-2009, 02:58 PM   #5
Chadlee2KZ's Avatar
Quote:
I think its about $7 a can. 2 cans should do it. R-134 or something like that.
Chadlee2KZ is offline   Reply With Quote
Old 09-16-2009, 03:05 PM   #6
01SuperSport's Avatar
Probably just needs some service. Same thing happened to me this summer too. Didn't use it all year and when it started to get hot, I turned it on to warm air just like you said. I figured it was just from it not being in use and it slowly started getting colder by the day and fixed itself
01SuperSport is offline   Reply With Quote
Old 09-16-2009, 06:25 PM   #7
check the belt on the ac pump and add freon
manwithhate is offline   Reply With Quote
Old 09-16-2009, 07:11 PM   #8
CoastieWS6's Avatar
More than likely you have a leak. So you need to find the leak and repair it and recharge the system with r134
CoastieWS6 is offline   Reply With Quote
Old 09-16-2009, 08:47 PM   #9
transam5.7lt1's Avatar
If the dryer is getting really cold on the engine compartment... it probably has enough freon in the system to work. If thats the case, you may want to take it to a professional, they will hook up the gauges and read the pressures, based on those readings they should tell if its like a bad expansion valve.
transam5.7lt1 is offline   Reply With Quote
Old 09-16-2009, 09:59 PM   #10
it's full of freon, line's are getting cool but not inside... maybe i should of made myself more clear of the problem thanks.
Old 09-16-2009, 10:03 PM   #11
bongva's Avatar
I'm also having the same problem, recently my ac compressor just locked up on me.
bongva is offline   Reply With Quote
Old 09-17-2009, 02:20 PM   #12
TireSm0ke's Avatar
Quote:
If the compressor clutch is coming on the belt is fine.
When it comes to A/C work, guessing will not solve the problem. You need to bring it to a professional to have them hook it up to a set of gauges, check for leaks, see if the system holds vacuum, etc.
It could be anything from a leaking o-ring to a clogged evaporator core, so your best bet is to take it to a pro.
TireSm0ke is offline   Reply With Quote
Old 09-17-2009, 04:09 PM   #13
jts98z28's Avatar
try goin to pepboys n buyin a can of r134a refridgerant and recharge it...i didnt read the other posts so my bad if someone already said this
jts98z28 is offline   Reply With Quote
Old 09-18-2009, 01:46 AM   #14
TireSm0ke's Avatar
Quote:
Dont do that. If the compressor clutch turns on then there is refrigerant in the system. Using the gauge they supply you with when you buy the canned R134A probably wont give you an accurate reading, and you could easily overfill the system. You could try it, and it will probably work for a few days assuming you have a leak, but it could lead to more problems in the long run. When it comes to AC work if you dont know what your doing you could easily screw something up and end up paying alot more money in the end. Just go to a proffesional and get it done right the first time. Good luck!
Old 09-18-2009, 01:55 PM   #15
do you hear loud grinding?
Old 09-18-2009, 11:49 PM   #16
Thanks guys for all of your helpfull input, took it to a friend of a friend that does ac work for a living and he fixed it in about 10 min.. problem was it had just enough freon to make compressor kick on but not enough to make it cool.. Thanks again JEFF
Related Topics
Thread Thread Starter Forum Replies Last Post
Lt1 95 firebird overheating ???? ugod02010 LT1-LT4 Modifications 14 04-01-2013 05:39 PM
A/C not cold TransAmcoupe98 Pontiac GTO 2004-2006 2 08-20-2011 05:26 PM
Heater help?? ITSAV Cadillac CTS-V 2004-2007 (Gen I) 3 12-03-2010 10:12 AM
Funky smell coming through vents + overheating issue + checklist miaminick Generation III Internal Engine 8 06-21-2010 11:09 PM
A/C blows warm and hot air only ARCTICWHITE98Z28 General Maintenance & Repairs 43 07-09-2007 01:00 PM
Tags
01, 99, ac, amount, belt, camaro, coming, compressor, coolant, evaporator, freon, kicks, test, trans, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
