AIR vaccum tube underneath fuse box
My air box does not have that tube running from it into the pump for the AIR system. There is just a small tube cut off and sitting right underneath the air box. Is this normal for some cars? If not, is it a problem? I have a 1998 Trans Am.
It's just that I'm really starting to run into a lot of problems with the car I just bought from a supposed mechanic.
I want to remove the AIR system but I have looked everywhere (this site included) and can not find a good enough explanation that I can apply right to my car. I get blocking the exhaust manifolds, I just don't know what to do with behind the intake. And whether I have to do this when I eventually buy a PP Typhoon intake.
stock airbox?
on the back of the intake, there are vac lines for the a/c, a black plastic cylinder under the passenger side frame rail, and AIR
the black plastic cylinder is for the A/C to switch the vents faster. it just stores vacuum. it can be removed (nothing to do with AIR). remove the AIR vac line and just plug the A/C vac line directly to the intake manifold instead of using the factory T-splitter. ill find a pic to better explain
the fuse boxes just snap into the retainer and the assembly attaches to the bracket on the fender and the lip of the hole where the AIR pump is/was, whatever the scenario is
here ya go. all the AIR crap can come off and remove all associated lines, T-fitting and just run the A/C vac line directly to the barb on the back of the intake
thanks!
that helps a ton with the intake manifold question. I has just always heard of freeze plugs and such being used in the back, but I take it that's only associated with blocking the front hole in an EGR removal with a stock LS1 intake.
thanks A LOT man! That offers some explanation. Its the whole fuse box assembly with the two boxes being attached. They just sit on stop of a vacuum tube that I haven't looked at but just assume runs down to the AIR pump.
So the tube I see running to the air box (particularly on aftermarket lids and cai's like volant) is for the A/C, not for the air?
unless u plan on deleting A/C and heat in the future, then all u will need to do is install a vac cap on the barb behind the intake. this is what i did since i trashed my A/C and heat for a drag setup
just pointing out all the options you have
ya the freeze plug is for the EGR hole on LS1 intake manifolds
i have a stock air box. i just always saw on aftermarket lids and cai's that there is a tube running right into the side of it. is this the same tube that's just sitting under my fuse box?
So if I remove the air, I suppose I just have to plug that when I eventually buy a lid or cai?
Thanks again for the help.
no problem, let me know if you run into any probs or dont understand anything and ill try to explain myself better
Ok, just to verify. In that picture the A/C line is not there correct? And I need to plug this A/C line directly into where I removed the small plastic AIR line and T fitting?
I've just seen in the past even you have mentioned some type of block off plate for the back of the intake. So I was/am confused.
I'm sure I'll figure this all out when I get ***** deep into this thing but I want to make sure not to mess anything up.
And I can't say this enough, thanks for your help.
no problemo. A/C line is not pictured. stock, it would go where the empty barb is on that T-fitting in the pic. yes, just plug the A/C vac line directly to the barb on the back of the intake. looks hell of alot cleaner than keeping the T-fitting and using a vac plug. the blockoff plates i mentioned in the past are for the EGR provisions on the intake (98-00 LS1), EGR provision on the passenger exhaust manifold and AIR provisions on both exhaust manifolds
no blockoff plates for the back. if i mentioned so in the past, i meant vac plugs if anything and thats if u keep the T-fitting
