Ram Air Questions - LS1TECH
Ram Air Questions
Thread Tools Search this Thread
Old 02-23-2010, 07:35 PM   #1
danbrazda's Avatar
Default Ram Air Questions
There's a reason this is in the newbie section, so stick with me here...
-Why wouldn't Ram Air work? I see all kinds of info on the internet saying Ram Air is all hype and strictly for looks. Isn't the principle behind Turbos, Superchargers and the like to get as much air into the intake as possible so you can burn more fuel and make more power?
-People say the WS6 Ram Air System does nothing except look cool. If the scoops on the hood were sealed how could the airflow to the intake be as good?
-Explain how after market lids make more power? They retain more volume in the lid but how does that equate to more volume through the throttle body?
I'll leave it there for now. Sorry if these are dumb questions but as I said, that's why they are here in the Newb section.
danbrazda is offline   Reply With Quote
Old 02-23-2010, 08:23 PM   #2
LS1W66's Avatar
The Ram Air hoods are NOT sealed to the Airbox and they have baffles inside to deflect water and keep it out of the engine. These 2 things make the hoods marginal at best. Do they help supply cool fresh air ? Yes is there a raming effect ? No.
But as has been stated on here and many other boards before if the Hoods were sealed to the airbox and the baffles removed you would still only gain about 3HP at 100+ mph.
As for the Air lid the restriction is the Oval part where the resonators are. Putting on an aftermarket Airlid will eliminate this turbulente area smoothing out the flow to the MAF and therefore make more power.
LS1W66 is offline   Reply With Quote
Old 02-23-2010, 08:28 PM   #3
LS1Tech Administrator
RPM WS6's Avatar
^ What he said. It's all correct.
RPM WS6 is offline   Reply With Quote
Old 02-23-2010, 08:32 PM   #4
chaman's Avatar
Yep...nailed it. Think of the "Ram Air" more in terms of a cool looking CAI (cold air induction system).
chaman is offline   Reply With Quote
Old 02-23-2010, 09:02 PM   #5
danbrazda's Avatar
Gotcha. Still seems a bit weird that removing the baffles and sealing to the air box only adds 3HP at 100mph. Isn't that the concept of the cold Air Intake systems that supposedly add a lot more HP than that (ie- adding outside air vs hot air from the engine compartment)?
Old 02-23-2010, 09:36 PM   #6
LS1W66's Avatar
Quote:
The reality is to be more functional the scoops would need to be more prominent (either farther out or higher up off the hood) and that would not be as astheticaly appealing.
Old 02-23-2010, 11:29 PM   #7
edzsilverss's Avatar
Keep in mind that most of the air that gets feed into the engine comes from the bottom of the car and not "just" the hood/ram air. That's why most do the free ram air mod on top of the hood version along with a shitload more money and mods. Look at my sig lol.
edzsilverss is offline   Reply With Quote
Old 02-24-2010, 10:02 AM   #8
mikedamageinc's Avatar
Default Ferrari 458 Italia
There is always a ton of questions about this and while it does seem like ram air should do a little at least, it's not worth the time people put into it. It doesnt take an engineering expert to know that fresh air is always better but the reason turbos and s/c work is because they compress the air, not just move it faster (which has been discussed at great lengths).
But what should be the final answer comes from recent articles in Car and Driver, Road and Track, etc about the new Ferrari 458 Italia. Ferrari claims the ram air system makes a whopping 5 hp at 200 mph. The fact is, most of our cars wont hit 200 and dont go too much over 110-150 in the quarter. So along the same lines you might get 3-4 hp tops at that speed. And the ricers that always talk about squeezing every last hp dont even hit 100 so you're talking 2-3 if you're lucky.
Bottom line is, do the free ram air mod if you want a few FREE ponies, get a ram air hood if you like the LOOKS. Get a turbo or s/c if you want the POWER.
mikedamageinc is offline   Reply With Quote
Tags
air, ls1tech, ram, strictly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
