Header gasket question....
Old 04-06-2010, 08:46 PM
99REDTRANSWS6's Avatar
Default Header gasket question....
Im gettin my hooker headers put on this friday... And a of buddy of mine that has a camaro says that I should go get a oem style header gasket cause the ones that come with my headers are junk... Any truth to that? I dont want to get them put on and the gaskets are junk.... Any info would be appreciated
Old 04-06-2010, 09:51 PM
09jyounger's Avatar
Chances are the gaskets that come with the kit are junk, they were with my pacesetters. The coolest part about the LS1 is the fact that the stock manifold gaskets are metal so depending on the condition of the stock ones, you can reuse them. If not, you can always make a trip to NAPA and pick up some OEMs. Good luck with the install, and keep us posted on your mods!
Old 04-06-2010, 09:58 PM
Yeah they look like junk.... I have some junk headers on it right now but they have horrible fitment and so I bought this pair.... Ill just go buy some oem gaskets it will be worth it in the long run we'll see....
Old 04-07-2010, 02:40 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Get the OEM gaskets, see the thread below
https://ls1tech.com/forums/generatio...-you-like.html
Old 04-07-2010, 02:48 PM
udienow's Avatar
stock gaskets for sure.... $20 and u know ur good.
Old 04-07-2010, 05:09 PM
Sweet appreciate it guys... goin to pick the gaskets after work.....
Old 04-07-2010, 07:13 PM
Another question I have a O2 sensor that has gone bad it says its bank one sensor 2 I have no idea how many sensors are on my exhaust... I have longtubes with ORY so does anyone know which one needs to be changed? Im guessin its the back sensor but just thought I would ask...
Old 04-07-2010, 07:27 PM
jsafe's Avatar
Gaskets=You can re-use the good ones on ur car now....
Old 04-07-2010, 07:30 PM
NSSANE02's Avatar
You should delete both of your rear O2's anyways so don't waste your money on a new sensor. Either get some sims or get them tuned out.
Old 04-07-2010, 08:11 PM
How would you go about deleting the rear O2's?
Old 04-07-2010, 08:37 PM
NSSANE02's Avatar
That
Old 04-07-2010, 08:54 PM
ahh lol thanks....
Old 04-10-2010, 12:47 PM
Well got the headers put on they still had a small fitment issue but nothing major.... The other cheap headers were thrashed the previous owner beat the tube that was hittin the kmember it was really bad... Ended up having to change out my Taylor wires that are six month old they were cracked almost looked dry rotted.... but on the other hand it actually feels a little more responsive and no more rattling...
Old 04-10-2010, 03:03 PM
FUN LS1's Avatar
You have 4; Bank 1 Sensor 2 is the rear driver's side O2 sensor...
I'd replace them all instead of just one, unless it's something like the wire melted and got grounded.
Old 04-10-2010, 06:25 PM
I actually got it wrong it was actually bank 2 sensor 1 and when I replaced the headers i found out that the rear O2's have already been deleted.... The o2 thats bad is because i bottom'd out and it crushed the wires just going to replace it...
Old 04-10-2010, 07:18 PM
NSSANE02's Avatar
O2's aren't cheap, why replace them if you don't need to?
Old 04-11-2010, 07:22 PM
FUN LS1's Avatar
I was surprised you reported it was the rear sensor, it's usually the front one that gets all nasty first. So that's the sensor in front of the cat on the passenger side.
...I guess cheap is in the eye of the beholder. I don't think they're that expensive, and if one was so nasty it was failing, the other can't be far behind; like cats...
Old 04-11-2010, 09:55 PM
cowboysfan's Avatar
13111 Bosch from autozone. part number is for a vette, but only difference are wires are longer which helps due to long tube headers and are higher heat range so that will help as well cause of headers create more heat...
Old 04-11-2010, 10:59 PM
FUN LS1's Avatar
Originally Posted by cowboysfan
13111 Bosch ...
Thanks, I was trying to remember what the alternative was...
