Quick gauge cluster question
I tried searching for some info. found this
https://ls1tech.com/forums/appearanc...meter-set.html
Check with 6LiterEater.... he may some knowledge on this
Just some additional info...
https://ls1tech.com/forums/pcm-diagn...-swapping.html
Just got done with the swap. . . . .
Alright, this is what I found.
1.The gauges fit just fine straight across. The TA gauges are just not pretty looking, the needles are orange and the read out looks kinda lame + the lighting is redish.
2. The mileage is kept in the actual LCD display piece and they are interchangeable.
3. The plastic bezel is not easily interchangeable between the TA and the Camaro, they are a bit different.
Good info, all learned the hard way.
