Will a good set of Roller Rockers free up any HP on a stock LS1 ?
Just as the title states will a good set of roller rockers free up some hp on my mostly stock ls1 ?
Thanks 2 anyone with info
Incresed rocker ratio (going from a 1.7 to a 1.8 ratio raises your net valve lift) will net some hp. But just installing rollers will usally give you more high rpm stability, and it may inturn quiet down your valvetrain at all rpms.
well i have to get headers but i dont really want to because i like the way my car sounds now i have the Slp Lm exhaust and i know if i get headers i will have to change my exhaust because it will be to loud
all aftermarket cams that i know of are ground for 1.7 rockers. if you get a custom cam ground for 1.8 rockers, then you will see a gain from the rockers. it will have the ramp rate and duration ground into it to take advantage of the added lift without speeding the valves up a lot.
before i built the engine, i had TSP TD's with dynomax bullets dumped. sounded really good, but it was loud as hell.
then i built the engine and installed a moser 9 inch and the TD's the way they were routed, wouldnt clear the larger rear end, so i put Moroso spiral flows right off the collectors, and it sounded good as well, but hella loud.
my next setup consists of the same x pipe i had with the TSP TD's, but with flowmaster 40 series delta force race mufflers. still going to be loud, but should sound great.
i like loud incase you havent noticed...
