04 corvette cam?
id go with a texas speed cam but in all honesty in a car like a 55 chevy your prlly gonna need more power down low. I can see much much much better results from a custom ground cam for your setup. Contact Texas Speed or another vendor and get a couple places to spec a cam for you. Tell them exactly what you want and expect out of it. You cant go wrong trust me. off the shelf cams are proven, but your applications and needs could be better suited by a custom grind and they are the same price as off the shelf cams.
custom grind call a sponsor.
as for heads, id say go with the LS6s unless you got a killer deal on the 5.3s. they flow better and you can mill 'em down for compression for some good low end grunt (which you are going to want in a 55 chevy).
coil packs- ive seen a few times on here the 6.0 coils are great. 5.3s should work, so again, if you have a deal on them, go with it.
