New Lifters with new Cam?
Are new lifters needed if doing a cam swap? Seems like they should be but most of what i have read sounds like they are just held out of the way during the cam install and reused.
I'm no expert, but I would say yes you should replace lifters. Also if you are going to be installing a cam that is anything but stock, I would replace vavle springs and pushrods too.
It's not a must. Obviously it is nice to change them but being that you have to pull the heads to swap them, most guys reuse the factory lifters when doing cam swaps. Typically you won't ever see an issue with doing this. A lot depends on mileage and how the cam looks when it is pulled out. But to answer your question, you don't have to change them if you don't want to.
Jon
Jon
i was looking around at cam packages which those are all included from what ive seen but they didnt come with lifters. Thats part of the reason i am asking about the lifters.
thanks jon! ive got 59k on the odometer. provided the cam looks good do you think the lifters will be ok? I wasnt thinking anything too aggressive because its my daily driver.
oh ok your probably good to go. the reason I recomended new lifters is because if I was doing it I would prefer two brand spankin new surfaces to contact eachother. Thats all. If texas speed says its ok, I would trust them. just make sure that the old cam has no serious marks on the lobes and such. Which I'm sure it doesnt. You have a low milage car.
Good luck with the install.
