Which one to buy a 6.0 or 5.3?
I hope this is the right area to post this. This is my first post here. First off i have a 98 Sonoma pickup with a 424 small block on E-85. Well it blew up two weeks ago and delayed the races for 30 minutes. So, now i want to build a LS style motor. I can pick up a 5.3 or a 6.0 motor at the salvage near my home with all of the wiring ect. But, what year and modle is the best platform to start with? I will probably leave the short block stock for a while. This is a race only truck that weights 3000 lbs with steel heads and me in it. I like to go fast so, what should i get? I also plan on using the turbo or supercharger i currently have. Thanks, Tim
Thank you. How much power can you make and keep the motor in one piece with a proper tune?
If its all the same.. the larger bore on the 6 litre will breath better with less valve shrouding issues. Since you are looking to run 10s, its a relevant point to consider.
Hope this helps,
--Glenn
Hope this helps,
--Glenn
