what is a "lid"
what is a "lid"
I know this is probably a dumb question to most of you, but I see it come up numerous times as a recommended part. Please enlighten me.
Big red arrow is pointing to it.
Sorry, had to.. You can pick them up for around 50-80$ shipped from the classified if you keep an eye on them. A lid is a lid is a lid, don't worry if it is a whisper/slp/etc etc etc it will all do the same thing and give you the same RWHP gains (4-7Rwhp or so).
Hey thanks alot guys, I have a stock one and would have never known I would get better performance by changing that out. I just wanted to do it for cosmetic reasons. Loved the lid joke btw.
No problem.
For instance...
http://susansternberg.files.wordpres...ecked-bowl.jpg
No doubt. Just be careful, you can "over lid" your Tupperware and it will not hold freshness as well, in return melting pistons...
For instance...
For instance...
LS1Tech Administrator
Received 1,471 Likes
A filter will do just as good (or bad) of a job at filtering no matter how much air you expose it too. Just because the air is dirtier or cleaner shouldn't matter in terms of filtration ability....only thing that should be effected is lifespan. Hence the reason why the filter will need to be changed more often when exposed to dirtier air.
Could work either way, a shorter lid would be like a dished piston and probably reduce compression. The taller lid would be domed and should boost compression based on a smaller chamber between top dead center of the tupperware and the underside of the fridge shelf. Unless of course you're considering the inside of the tupperware to be the chamber and the lid to be the head, in which case you'd then be correct.
