Leak in rear end, money's tight...
What do I do? I don't think it's a bad leak, not finding any fluid in my parking space- but you can definitely see it on the car itself... Is there a stop-leak I can add or anything like that that will help me avert an expensive repair? I'm a noob at this stuff, help me out here guys. What am I lookin at?
Rear pinion seal more than likely. No, there isn't stop leak you can use and I wouldn't recommend it if there was. It isn't that hard to change out but you do have to be careful. If you don't really work on your car I wouldn't recommend changing it yourself.
The seal itself is only like $12 from the auto parts so it won't cost too much to have a shop put it in for you.
LS1Tech Administrator
Received 1,486 Likes
Where ever this leak is from, so long as it's not leaving spots on the ground, then it's minor enough that you can just keep adding fluid to the diff (whenever it gets low) until you can fix it.
The fluid level should be right up to the bottom of the fill plug hole on the passenger side of the diff housing.
had same issue
awhile back i had the same problem,i went to different auto shops to see what the problem was they said the pinion seal, which is like 15 dollars, but i payed some auto shop 60 dollars for labor. so my total was 75..but be careful alot of shops wanted 500 + to fix...lol idk why but they did ...the shop i took it too fixed it and it has not leaked sense.
Cool, thanks guys. I appreciate the wisdom, hopefully it is just a seal- and at least now I know what to look for and won't get taken for a ride at the shop...
