hey
hey
hey mine new hear on the site
I have a 1999 trans am auto
I have a hp tune
I have 150,000 miles but have alot of new parts on her ,,,and a 2 year warrnty on motor but that later,,
but when I break torque my car the wheels jump bad
now when im on smooth road and I just hit the gas its fine but if i hit the gas on a shi**y road it does this.
can you guys help me out
thanks
I have a hp tune
thanks
so where are you from?
if i'm reading correctly it sounds like you need some stickier tires and possibly new shocks and lower control arms. your english seems to be a little choppy so i apologize if i'm not understanding you entirely.
Wheel hop is usually caused by poor suspension geometry and failed or low quality parts.
Get some adjustable lower control arms, some weld-in lower control arm relocation brackets, and some new shocks and you should be golden.
#2- Quit torque breaking on gravel roads.
#3- SPELL CHECK!!!!!!!!!!!!!!!!!!!!
I have a hp tune
thanks
I have a hp tune
thanks
LS1Tech Administrator
Received 1,462 Likes
At 150k miles I'd start with some new rear shocks and inspect the rear lower control arm bushings (replace if rotted/cracked). That's probably all you need to prevent wheel hop (the condition you're describing) at stock-ish power levels. May want to check the torque arm bushing as well.
If the car has been lowered, then you should look at relocation brackets for the rear lower control arms. Otherwise, I would not worry about that at this time.
Ok thanks
and some of you arent being kool
and im 18 years old
had the car for 2 years and also had the lt1 also but sold that one
I no I just got a new rear end and gears 342
and im 18 years old
