new intake?
new intake?
If i get a 96mm intake manifold what else i hav to get to adjust with it? I know a new TB but what else? I hav a slp lid but i need anything else or can i just bolt it on with a tb?
If it didn't came with the intake, you will need TB seal and port seals and the other stuff could just swap to new intake!! if you want you could change the injectors o-rings I will only change them if you see they look old and have little cracks other then that i will just put some grease to prevent them from cracking and finish
not in a bad way but why would you upgrade to a 92mm? im guesing a FAST? your only going to make more power with that large of an intake if you have a cam setup to take advantage of the added flow. id just put an ls6 intake on if i were you.
Ok so i went with every1 and got a ls6 intake and ported tb. So next question will it run the same if i dont tune it or get worse? I kno i have to tune it to get the hp but i dont wanna spend all sorts of money on a dyno just for an intake. Will it be fine installed for a month until i get my full exhaust on or should i just wait until i install my headers and catback? And i hav a diablo tuner, can i adjust it on that?
