lets talk emissions
lets talk emissions
im gonna be stationed in colorado soon and i hear the emmisions tests are strict there (have to pass emmisions to get a pass to park on base). my car has no cats because of the long tubes i installed. and the egr is deleted bc of the ls6 intake swap. ses light is on because the 02 sensors are going nuts since i removed the cats. would i be best off to just buy 02 simulators and weld in a hollow cat after the y pipe? or would they actually run that thing up in the exhaust pipe to check the gasses coming out?
Well, if they use a sniffer you're screwed unless you put cats on. But if they're just gonna plug up to to your ODB II port then you have a few options, sims being one. I'm not sure if you're able to just tune out the post cat O2 sensors on these cars without having issues; but if you can that's probably your best bet.
o2 simulators have been known not to work. It is best to take it to a tuner who will tune out the rear o2 codes.
If they also have a visual on top of OBDII check, then you need either gutted or fake cats.
If they have a sniffer test, you're screwed and need cats.
Find out exactly what is required for the emissions testing and go from there.
LS1Tech Administrator
Received 1,471 Likes
Exactly!! I may be going to Fort Lewis soon but im gonna keep my car registered in LA. If your horn and lights work you pass here! I've never changed my plates on my vehicles when I pcs.
