tach not working
tach not working
i pulled my motor apart an painted the engine bay. but before that it worked.
we pulled the heads off, tore it down to a shortblock, threw arp rod bolts in but didnt leave cyl 1 tdc. threw cam/lifters/ls2 chain
so some people are saythng thats why my tach doesnt work because the crank an cam are out of sync an i should do a crank relearn.
i turn the key on an it makes a sweep, i gues thats a way of teling it needs a relearn as i was told.
no cut wires or poinches, new cam sensor.
maybe bad ground due to painting block an bay?
its driving me nuts an im throwing 2 codes ones p0342 n idk wat the other was.
Hmm i rented a obd reader an it says im throwing no codes, im gonna move both block grounds to the front, so i kno i sanded the paint off the block good... it has to be something stupid
LS1Tech Premium Sponsor
Check the cam sensor and the wiring to and from that sensor. Also the grounds on the back side of the cylinder head; make sure they are clean and tight!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
And on the code reader I hope it was cheap to rent because you can buy one for $70 now if it reads all the engine peramiters that is a different story but just codes you can get one cheap.
New cam sensor wires r clean i pulled the loom back to main harness..
Im moving the ground above starter up move to a spot i knows clean.
Also on the starter the 5/16 nut is that a ground? If so its not tight.
