how to tell heads from heads
Old 09-04-2010, 04:55 AM
1FOUNTAIN's Avatar
Default how to tell heads from heads
i am looking to buy some LS2 heads from a local guy i was wondering if there was any thing i could look for on the heads to no that they are LS2 heads thanks
Old 09-04-2010, 06:29 AM
garygnu's Avatar
the casting number on the head.
Old 09-04-2010, 06:39 AM
Trunion King
bene's Avatar
LS2 heads can be either 799 or 243s.
Old 09-04-2010, 03:13 PM
1FOUNTAIN's Avatar
thanks will the numbers be easy to find, and what are 317s
Old 09-04-2010, 04:21 PM
garygnu's Avatar
yes ,they are on the out side.
Old 09-04-2010, 06:17 PM
1FOUNTAIN's Avatar
thanks for the help what is the difference between 799 and 243s
Old 09-04-2010, 08:49 PM
ULTIMATEORANGESS's Avatar
i never knew that. my GTO has 243 stamped on them.
Old 09-04-2010, 10:27 PM
1FOUNTAIN's Avatar
are the 799 heads from vets, and witch are better
Old 09-04-2010, 10:37 PM
Hard Core Z28's Avatar
317 are truck 6.0 heads
Old 09-04-2010, 10:46 PM
Z28_LT1's Avatar
I'd say the 243's are much more common.
I didn't know that ls2 and ls6 heads were interchangeable. That can't be right, they're different generation motors.
Old 09-04-2010, 10:50 PM
the jester 812's Avatar
heres a good read on gen3 heads
http://www.carcraft.com/techarticles...ads/index.html
if you go to the next page it will tell you the casting numbers on each head
Old 09-04-2010, 10:58 PM
Formerly 99-2door-08/30/2010
PitchblackC3's Avatar
I thought this was pretty common knowledge here, but I guess not.
The 243s were used on the LS6 and LS2 along with some later 5.3L truck engines.
The LS6 had sodium filled valves, the LS2 and 5.3s did not.
There are 2 different castings of 243s, they are identical but the casting process was different resulting in smoother ports on the ones with a triangle casting mark below each plug hole. Google it and you can see some pics of what I am talking about. If you are going to have them ported this really doesn't matter.
GENIII vs GENIV doesn't really matter on the heads so much, the LS2 is still a cathedral port heads engine. People run L92s on GENIII LQ4s and LQ9s. GEN doesn't matter in this case.
Old 09-04-2010, 11:04 PM
Z28_LT1's Avatar
Good info.
I was under the impression that they weren't interchangeable because of the different generation. Thanks for clearing it up.
Old 09-04-2010, 11:28 PM
garygnu's Avatar
l92 heads gen 4 will not work on ls1 gen3 blocks,valves are to big.243 z06 heads are vette heads with sodium filled valves.
Old 09-05-2010, 12:13 AM
^^ this^^, they require a 4.0 or larger bore and l92 heads have square intake ports that require a l76 intake or aftermarket equivalent.
Old 09-05-2010, 06:49 AM
1FOUNTAIN's Avatar
wow thats a lot of info i was just wanting to put ls2 heads on my 98 trans am ls1 because i am turboing it, and i read ls2 heads would lower the compression but with all these options i guess i need to read a little more
Old 09-06-2010, 10:43 PM
Yes, but that is a function of the bore size, not the GEN. The L92 heads will fit on a LQ4 or LQ9 because they have a 4.0" bore.
Old 09-07-2010, 03:27 AM
Tobias05's Avatar
the 317s will lower compression. same design as 243s but with 72CC.
Old 09-07-2010, 08:58 PM
^^this^^ as i have a lq4 408 with l92 heads on it.
