fuel injector question
was lookin at upgrading my fuel injectors possibly, could i use some out of like GTO 6.0L's? if so is it worth getting them and doing the upgrade or no?
ls1, with diff lid intake set up and full LT catback exhaust, but gettin heads and cam in about a month or less depending on money so, what are these redtops u were talking about, any more info on them?
ight cool thanks, deff look those up and try to get a set, think it will be worth it to get before i get my heads and cam before the tune? or is this something i could do after that and when i get my TB ported and LS6 or FAST intake and re tune?
The best bang for the $ is the SVO redtops, which are 30# ford injectors, but around 36# @ the fuel rail on LS1 cars. They plug right into your pigtails, nothing else is required (other than a tune) and can be had for 100-150$.
If you're doing heads AND cam you'll want to pick up some injectors. Cam/bolt on's/intake and the duty cycle is usually in tolerance. Adding heads would put you over the "tolerance"
That is right my bad... and the Greentops are 42#'s at bar 3 fuel pressure so about 48#'s at our bar 4 fuel pressure.... I run 42# (@ 3 bar) Bosch design III's on my car.....
