ls1 fresh build no oil pres.at idle
just installed ls1 in car started engine have no oil presure at idel
but when you give some gas presure will go up.
soon as you go back to idle goes back 0.need help.
new ported pump,and oring,plugs are in block.
i read this is a common problem...
thanks for your input found problem i installed double roller timing chain they come with
shims installed one the wrong way that was the problem.
P S thanks for the help......
