biggest cam on a 5.3 l
i just got a 5.3l ..cuz my ls1 spun a bearing,..so i need my car running again and i got torquer cam v2 232/234 cam and iam thinking if i can put it on the 5.3 liter motor... but heard to many saying that 228 232 is the biggest on a 5.3 l ive heard..so wat u guys think should i put it? this with stock 862 heads...but there selling me some 241 ported would that work on my 5.3l with that torquer cam? thanks in advance
I ran a 232/236 .595/.601 in my stock 5.3 with stock converter and 3.73 gears, daily drove the **** out of it, 20+mpg, I cut the EXACT same 60' with that "big" cam as I did with my stock cam, but gained a lot all the way down the track...No low end loss here. All the drivability is in the tune up. Mine didn't buck or ever want to die, drove like stock, just sounded badass
LS1TECH & Trucks Sponsor
I am glad you were able to get that large of a cam to work with a stock converter on a 5.3l motor. I have never seen that done. From what I have seen in the past, cams that large usually don't work so well in that small of a motor.
That cam with no converter on a 5.7l would be terrible to drive, again this is just from what I've seen.
Terrible to drive or to race? We've had a 244/248 cam in my truck, just because I needed to drive it and didn't have anything else and it still DROVE stock-like...no bucking, no idle issues, no two footing or wanting to die.
It sounds to me like the guy is just wanting to have a nasty sound...for that, the cam he is wanting to use is a great choice in my opinion. I'd use it, and a good tuner and never look back.
Not trying to argue with you or come off as a dick, just explaining to the OP what we've been, what I consider, successful with. If he doesn't have someone that can tame that cam down in the tune, then no, he probably shouldn't use it.
Terrible to drive. You must have an awesome tuner to be able to get those sized cams to drive like stock in a 5.3l motor. They are much larger then anything we have ever tried to put in a 5.3.
I am not trying to argue either, you are just doing stuff that doesn't make any sense to me.
LOL yeah most people say we're retards
My truck has never been anything that I would be scared to let my 80 year old granny drive. I can walk outside at any time, fire it up, put it in drive and go and it never skips a beat...But yes, it definitely requires a great amount tuning.
How big of cam can you run in a 5.3
I am running a 609/621 lift cam with a 111 lsa in my 5.3 just raced it this last weekend . I have 78 ls swap camaro with 3:23 posi ported heads springs lifters push rods etc the bottom end has a 133 k on it th 350 trans 3500 stall and im running high 12's on motor alone with street tires good year f1's on ZO6 18'/17 rims anyways the bigger the cam the better this is the first ls ive built and I wont ever build any thing old school again intentionally . Go big or go home on the cam shaft man !
What are some options as far as off-the-shelf cams that could be put into a 5.3? The 5.3 will be going into a 2002 Trans Am, weekend warrior/cruiser. I just want to add alittle sound and power over the stock cam.
The bigger the better
I would run a 625/625 from howards you can pick up the whole kit spings pushrods double roller timing chain etc off ebay for about 900 bucks as long as you port your heads you should make nasty hp on the cheap !
What cam would best fit?
Hello everyone. I have a 04 tahoe with a 6 inch and 35s. Im investing inna tuner but was wondering what cam would best fit for a stock 5.3l. Also investing in headers as well. Ive been told a cam and a torque converter would be good for it. Just looking for opinions. And i intend to use stock heads.
It seems as though you may be on a little bit of a tight budget if you are putting a 5.3 in your TA. Thanks guy an TSP has a point there are much better cams for a 5.3. Will it run better than stock, **** yeah. Will it lose some down low, probably. If that cam is coming from your blown up LS1, I would use caution. When you do a cam swap and don't upgrade your oiling system **** goes boom.
