Oil Change - LS1TECH
Old 05-06-2016, 02:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
Oil Change
Thread Tools Search this Thread
Old 01-09-2011, 10:32 PM   #1
Question Oil Change
My car is approaching 81,000 miles and I was wondering what would be(in your opinions)the best oil that I could put into my LS1?
-02 camaro z28, slp lm1, hypertech prog.
kellogg22 is offline   Reply With Quote
Old 01-09-2011, 10:48 PM   #2
SS1Eagle's Avatar
If you love your Z28 then some TLC at any cost is worth the personal investment. Here's the parts I installed and my SS loves me now.
SS1Eagle is offline   Reply With Quote
Old 01-09-2011, 11:28 PM   #3
Another good Q, do you believe in E3 spark plugs or just stick with NGK?
Old 01-09-2011, 11:38 PM   #4
metalmilitia606's Avatar
You're going to get a million responses on here. Oil is all a matter of personal preference when it really comes down to it. Any name brand synthetic oil will do the job. I run mobile one in my car and have no problems with it.
metalmilitia606 is offline   Reply With Quote
Old 01-09-2011, 11:40 PM   #5
stick with NGK TR55's
and for oil, LS1's love German Castrol Syntec 0w30 with a quality (i.e. K&N) oil filter
you can get good deals on it at autozone sometimes, so keep an eye out
therealcreeper is offline   Reply With Quote
Old 01-10-2011, 12:18 AM   #6
If you're stock, get some NGK TR55's and gap them to .50
As far as oil goes, I always have used Mobile 1 5w30, and a mobile 1 filter.
westtexasbuff is offline   Reply With Quote
Old 01-10-2011, 12:24 AM   #7
cookba's Avatar
that Amsoil batch is gonna cost you a pretty penny each time. "MOST" LS1'ers use M1, GC, and Penzoil Platinum with a K&N oil filter or AC Delco. NGK TR55 are the only plugs you need for now.
cookba is offline   Reply With Quote
Old 01-10-2011, 12:51 AM   #8
RedHotG8's Avatar
With 81K on the clock it's kind of late for an expensive synthetic oil like Amsoil. It's not going to undo the wear that the motor already has at this point. If you use M1/Penzoil/Valvoline synthetic and a good oil filter like NAPA gold or K&N, it will protect the motor for many trouble free miles.
RedHotG8 is offline   Reply With Quote
Old 01-10-2011, 07:52 AM   #9
Internet Mechanic
BlackScreaminMachine's Avatar
Well considering that if you have not put Syn oil in the car for the first 81k or so miles then do not bother switching. Chances are you will blow up a piston before a bearing goes out and when you rebuild then maybe considering using Syn from the start.
I use regular Dyno oil, the car is driven mostly in Spring/Summer/Fall, no winter and even if it was, I would not be worried.
Best as in ANYTHING is a very subjective term. Technically Best for me is what is cost efficent and what the car likes. Frankly I put just about 3k on a car a season and techincally I could do a oil change @ the beginning on Syn. Go a whole season, leave it in over the winter and change fresh @ the Beginning again.
Or do 3 seperate oil changes @ 1k mile intervals for around the same cost and your not hurting it by doing that.
I run Mobil Clean 5000 on a AC Delco Filter. I might consider a Napa Gold Filter for the 6.0L as it has some more capacity. IF I was to consider Syn, then I would look @ Pennzoil Platnium.
As for the rest of the Tune-up Look at other things and I will say when I did my cam @ 35k I did everything except bleed out the older brake fluid.
Coolant- Prestone (mixes with anything)
Plugs- NGK TR-55
Wires- LS6
Pads/Rotors- Top of the Line Autozone (Front/Rear)
Battery- The Positive Post rotted off, Autozone
Wipers- RainX (honestly for the times it sees rain, could have been generic)
Fuel- Autozone brand
Oil- Mobil Clean 5000 (recommended weight)
Oil Filter- AC Delco
Serp Belt- Gator Back (matched to the SLP U/D Pulley
P/S- Flush/Fill
Transmission Fluid- M6 Pennzoil Synchromesh, A4 Dexron ATF & Filter
Air- K&N Recharge which took a few days letting the oil dry and set.
This stuff adds up, even when you do your own work.
BlackScreaminMachine is offline   Reply With Quote
Old 01-10-2011, 08:15 AM   #10
Ls2SilverBullet's Avatar
I have run Royal Purple 5w30 and either a k&n or napa gold filter since i bought the car 16000 miles ago. Motor has about 42000 now. Never had a problem
Ls2SilverBullet is offline   Reply With Quote
Old 01-10-2011, 10:28 AM   #11
98z8uup's Avatar
I use what every synthetic oil that on sale with a a/c delco filter, but I do not use Q-Shake. Have not had and problems. The key is to change your oil.
98z8uup is offline   Reply With Quote
Old 01-10-2011, 10:47 AM   #12
MonmouthCtyLS7's Avatar
Amsoils good but a little pricey...Ive use just about every full synthetic on the market(mobile 1, Pennzoil plat & ultra, amsoil, etc. and alll have been good, go w/ the best price...K&N or mobile one makes a good oil filter, just stay away from Fram filters.
MonmouthCtyLS7 is offline   Reply With Quote
Old 01-10-2011, 10:51 AM   #13
Quote:
Huh, says who? I had an oil leak when I first bought my car...a few synthetic changes and the leak was no more....Id have to disagree w/ you, I definately believe it helps recondition seals along w/ cleaning out previous wear/sludge.
Old 01-10-2011, 11:39 AM   #14
Quote:
What?
The negative side to switching to synthetic after having ran conventional for so long is that conventional sludges up, and while that isn't good in and of itself, it blocks leaks. Synthetic will clean that sludge, and may present a leak (not cause it), if it's already there. Even so, fix the leak and run synthetic.
4WOFURY is offline   Reply With Quote
Old 01-10-2011, 11:46 AM   #15
Juggernaut TA's Avatar
so does or has anybody used the high mileage oils for LS1's over 100k? my dad seems to like the valvoline 10w30 high mileage version?
Juggernaut TA is offline   Reply With Quote
Old 01-10-2011, 12:17 PM   #16
thunderstruck507's Avatar
I have always used pennzoil platinum in mine, but just picked up some german castrol on sale and I'll be damned if the ticking I've had since I first fired the ls1 swap isn't literally gone now...
Think I'm going to stick with the castrol now, the engine is much less annoying with it
thunderstruck507 is offline   Reply With Quote
Old 01-10-2011, 12:19 PM   #17
The House is Rockin'
BLUES MAN's Avatar
im another pennzoil platinum user, im very pleased....
BLUES MAN is offline   Reply With Quote
Old 01-10-2011, 12:21 PM   #18
Internet Mechanic
Quote:
Originally Posted by 4WOFURY View Post
What?
What I stated had ZERO to do with what you just said.
My stand point is on Bearing/Cyl Wall Health. Wear on the engine is measured on these parts mainly. What becomes the ROOT cause of a rebuild generally does have to do with.....
1) Head Gaskets
2) Piston/Rod Damage
3) Bearings
4) Block Damage
Being that a motor that is PROPERLY maintained with conventional oil for 81k Miles will not see nearly the benefit of life so late in the cycle as it would have if it was swapped with in the first 10,000.
Syn absolutely have their place but what I said was an opinion. But do not twist my words into something that is not.
As for "Sludging" get off the TV and stop watching commericals. Sludging occurs primarily on engines with POOR service cycles. Not changing it regularly is what leads to this issue. Period.
Depending on the set up, be it a 87 Grand National Motor or Nitrous Spec'ed LSx based motor is not only is recommended to run convential, but to run a very thick weight due to ring gap specs.
So what works on one does not work for all. But one piece of advice that will encompass possibly EVERY single engine ever created in all of exsistance is simply....
Maintain proper Service Cycles!
Old 01-10-2011, 12:28 PM   #19
I'm also a pennzoil platinum user, with the longer WIX truck filter for 6 qts.
I use this stuff in both my cars.
mischief is offline   Reply With Quote
Old 01-10-2011, 12:52 PM   #20
Omega Doom's Avatar
I use the high mileage Valvoline 10w30
Omega Doom is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
How much oil does my t56 take? 98 ls1 jimbo Manual Transmission 3 03-01-2013 12:29 AM
What oil is best for my cammed ls1 blacknyellow Generation III Internal Engine 66 03-10-2012 08:12 PM
thumbs up to Marvel Mystery Oil rich Z Generation III Internal Engine 5 02-25-2012 08:15 PM
Oil Pressure HELP! lsxhaley Conversions & Hybrids 11 02-02-2012 08:58 PM
Moroso LS1 oil pan question Cliff Generation III Internal Engine 7 01-23-2009 11:08 PM
Tags
2002, 98, camaro, capacity, change, gap, high, ls1, ls1tech, mileage, nitrous, oil, pontiac, ring, trans, type, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
