Cold Air Intake and MAF Sensor Install
Old 04-21-2011, 03:06 PM
Tuefelhunden's Avatar
Default Cold Air Intake and MAF Sensor Install
I have a '99 Trans Am. I installed a K&N Cold Air Intake. Now I want to install a new 85mm SLP MAF Sensor to replace the stock 75mm MAF Sensor. I was told by K&N that the tube connecting the air filter to the MAF Sensor will not fit over an 85mm MAF. Does anyone know what I can do to install this?
Last edited by Tuefelhunden; 04-21-2011 at 03:29 PM. Reason: Added wording to title
Old 04-21-2011, 05:19 PM
r4dio78's Avatar
Do you mean you bought a KnN Filter or did you buy the whole KnN Air Intake Kit? If its just the filter i think any aftermarket lid will work. i have a SLP Lid on mine.
Old 04-21-2011, 05:26 PM
thompson's Avatar
with a smooth bellow intake you should be able to fit it, stock probably will not stretch enough. Keep in mind that you must get a custom tune when you install the new MAF.
Old 04-21-2011, 06:48 PM
justin hover's Avatar
why are you installing a new maf? your stock one can handle over 450 hp
Old 04-21-2011, 07:26 PM
I have some $$$ to put into the car and just thinking further ahead. I'm working with a guy here in Houston and when said and done, will be 500+hp.
Old 04-22-2011, 10:48 AM
cookba's Avatar
well at that level, dont use a SLP MAF go SD or get a TSP 100mm MAF
Old 04-22-2011, 10:25 PM
dutinsss's Avatar
i'm running a K&N kit with an 85mm MAF sensor. it's a tight fit but it'll work. put the 2 pieces in the oven for a little while and they'll fit much more easily.
Old 04-24-2011, 11:21 PM
The Scammer Hammer
dr_whigham's Avatar
IF he's running the SLP MAF, and specifically the SLP, it has the resistor in place for his stock tune. He will not have to retune for it.
I'm with the rest of the guys though. No use in getting it. I'd spend the money elsewhere, like exhaust or a mail order Frost tune. You'd be surprised how it peps up even a stock car.
Old 04-25-2011, 08:29 AM
Awesome. Thanks for the help guys.
Quick Reply: Cold Air Intake and MAF Sensor Install
