Plastic tank fuel level question
I have a plastic LS1 tank that I am putting in my 1989 Camaro along with a LS1 and T56. The stock fuel level sending unit reads 33-240 ohm...
Here is my question to you....
My new fuel gauge dose not read 33-240, it's 240-33 ohm. I was going to bend the float arm so that it faces the other way... Thus correcting the problem.
I thought the fuel level data was sent to the PCM for EVAP calculations... wont this throw off the EVAP system? This needs to be a smog legal swap.
I am not sure if the PCM recieves a signal or not from the sending unit. I know the gauge uses the resistance value to determine the fuel level. I also know there were differences in the 98 models and the later 99-02 pcms and gauges. I have a factory manual at home for my 98 with all the schematics, If your dealing with the 98 setup PM me and I can try to trace out some of the fuel circuit.
Thanx for the response... I got it figured out...
Buuuuut, I have another problem. I have a 99-02 style plastic tank but I have a 98 LS1.
I need to hook up the EVAP system. Can the two be made to work together?
At the time I got the tank, I thought the only difference between 98 and 99-02 was the placement of the canister. Will it still wire up the same??
