ms4 + nitrous?
ms4 + nitrous?
I just recently bought the ms4 cam and was curious if this was goin to do good with my 100hp shot of nitrous? If not i dont mind taking the nitrous off. Also what all do i REALLY need to go with this cam other than pushrods and springs?
Any suggestions appreciated
The ms4 will work fine with nitrous, just make sure your tune is good. You definitely need springs and pushrods and I would recommend a new oil pump, timing chain and maybe lifters, depending on the mileage of the motor. I would also add an underdrive pulley since it will be off anyway.
It should handle that kind of shot fine. Make sure you upgrade your fuel pump! Upgrade your injectors if it is a dry kit. I went ahead and threw in a ported oil pump for peace of mind on my kit. Seeing as how you have a 99 I would throw on an ls6 intake on there if you don't have one already! To get the most out of your cam kit you should go ahead and throw some long tubes and an off road Y pipe or full exhaust!
