What did I do wrong
Old 06-20-2011, 07:23 PM
wicked383lt1's Avatar
Question What did I do wrong
I just installed my p&p throttle body and now the car idles at 1000rpm and it seems to stick when I rev it up.Also it starts to increase and decrease in idle. All input needed.
Thanks Mike
Old 06-20-2011, 07:38 PM
TImmy_Jones's Avatar
Sounds like the throttle cable is stuck/sticking. Check that, make sure it is all clear.
Old 06-20-2011, 07:49 PM
Update...the cables are not sticking and now the rpms are fluctuating from 750-1100. This is some weird ****!
Old 06-20-2011, 08:00 PM
95 mystic ls's Avatar
Sounds like a vacume leak or your IAC isn't working right.
Old 06-20-2011, 08:12 PM
I'm leaning toward me not installing it correctly I'm gonna try again...brb
Old 06-20-2011, 08:30 PM
sjsingle1's Avatar
pull the positive cable off the batt to reset the computer
Old 06-20-2011, 08:36 PM
babbage1109's Avatar
Clean your tps and iac
Old 06-20-2011, 08:54 PM
Well I took it off and put it back on and also did these steps...
Key off.
Unplug TPS.
Turn key on for 5 seconds.
Key off.
Plug in TPS.
Turn key on. Closed throttle should be 0%.
Old 06-20-2011, 08:59 PM
Can I use maf cleaner?
Old 06-20-2011, 09:25 PM
The Scammer Hammer
dr_whigham's Avatar
It's going to idle like **** for about 10 minutes. You need to drive it in traffic, then turn on the AC and drive 10 more minutes; Your PCM has to do an idle relearn.
Old 06-20-2011, 09:27 PM
Starz T/A 17's Avatar
Who ported the TB? It could be that it wasn't done correctly and its not sealing completely. And as far as the TB sticking when you press the gas all of my P&P TB's had that feeling compared to stock just takes some getting used to
Old 06-20-2011, 09:33 PM
The guy has a great rep here on ls1tech and I only seen one complaint...I do understand that **** happens...tomorrow I will drive it around,I'm just not getting thd turn the a/c on part?
Old 06-20-2011, 09:43 PM
The ac belt on the engine...it idles different with ac on or off
Old 06-21-2011, 05:49 AM
All I did was swap tb's and that's when the problem accured,before that the car ran and idled like a champ
Old 06-21-2011, 06:19 AM
NO ik that's fine I mean when you said idk about the ac part. It's to relearn the idle...because it idles differently but driving it should fix the issue it just needs to relearn it. I have one from the same guy and mine runs great
Old 06-21-2011, 06:33 AM
Is the amount of air coming in that big of a difference compared to stock?I'll drive it after work and post up the results around 6pm
Old 06-21-2011, 04:59 PM
Update...I drove it it seemed like it stopped until I got home now. I drove with a/c off for 10mins then on for 10mins and nothing. I drove the car for over an hour and now the rpms also stay at 1000rpms. So what now?
Old 06-21-2011, 05:01 PM
Is it idling constant?
Old 06-21-2011, 05:12 PM
It Was and when I got home it started the fluctuating again...before that it stayed at 1000rpms
Old 06-21-2011, 07:17 PM
Com'on guys don't give up on me!
