2K to spend............what would you do?
Old 06-22-2011, 03:48 PM
BLKZ28VERT's Avatar
Default 2K to spend............what would you do?
Alright, i have been saving for over a year now and have approx. 2K to spend on mods for my 1998 Z28 Convertible. Up until Monday i had my mind made up on purchasing some American Racing Headers (W/EGR/AIR) & Catted Y pipe. I do have the option of deleting this, as it is not a requirement in my state, however i am skeptical at removing it. Anyway, after conversing with a few of you, it sounds like i would be limiting myself on the Intake side if i were to keep the EGR/AIR as the LS6 does not offer this (unless i want to buy a new one at $670.00).
So at this point, i am back at square one wondering what the rest of you "experienced modders" would do? What would you do to your bone stock (other then a lid) LS1 w/ $2000.00
Thanks,
BLKZ28VERT
Old 06-22-2011, 04:21 PM
Tobias05's Avatar
I think I'd go ahead and get the non emission ARH 1 7/8s headers with ORY. Very nice quality headers, have seen them in person.
-roughly 1300$ for the ARH stuff from Speed Inc.
-Used LS6 intake, 200-300$, depending on luck
-Frost Mail Order Tune, $150
-Some sort of 3" catback, 400$
If you didn't need the catback, I'd get a cutout, an UDP, and then send out the TB to be ported. Or, if you're an auto, keep the leftover cash and save up a bit longer and get a good stall converter.
Old 06-22-2011, 04:28 PM
lemons12's Avatar
Goals for the car? You care about fun on the street/sounding good/best bang for buck/best et per mod?
For exhaust... I recommend TSP 1 7/8 with the Ypipe. Get your choice of muffler and/or a cutout. You will have around 700$ in this exhaust setup and will outflow any 1 3/4 setup. If you really want to do it right and have a bad *** exhaust, get a flowmaster merge instead of a normal y pipe.
Get rid of all the emissions bull **** and don't go catted if it isn't mandatory.
Ls6 intake 300$
lid 50-90$ (slp brand new for 90$, used for cheaper.. a lid is a lid)
sub frame connectors!! 150-250$ish
You will want a tune after this.. If you plan a cam swap soon after this, get a mail order... If you don't, I suggest a dyno tune. Frost does good mail order tuning.
This will be very close to 2K, you will have a little left over. It will be a nice bang for the buck.
If you have an auto, I recommend a PTC converter and a trans cooler in place of the ls6 intake.. That will use all your money but a converter is THE mod you HAVE to have for an A4.
Old 06-22-2011, 05:03 PM
ULTIMATEORANGESS's Avatar
what trans do you have?
i like ARH LTs.
Old 06-22-2011, 05:07 PM
BLKZ28VERT's Avatar
.............its an M6.
As for my goals. I intend on owning the car for the rest of my life. I purchased it from my uncle being the only other owner of the vehicle (10,400 miles on it). So i want the best of everything, and i am in no hurry to get there. I just figure that a nice header/y pipe combo would be a good start.
It is by no means my everyday driver, but i like to have fun with it.
Not sure if that helps.
I have done a little research on the Catbacks, and the only one that i really like the look of is a CME, but i think this is more of a Mod that you do to your exhaust with the tips? Am i correct on this, or is the center mount exhaust a whole cat back system like say magnaflow?
Old 06-22-2011, 05:12 PM
Smile
ls7 clutch is a nice upgrade.
Old 06-22-2011, 05:20 PM
lemons12's Avatar
In that case.. I recommend kooks 1 7/8 with their new xpipe setup.
Old 06-22-2011, 09:50 PM
BLKZ28VERT's Avatar
is the stock clutch not good?
Old 06-22-2011, 10:00 PM
garygnu's Avatar
do poly motor mounts when you do the exhaust.if you need any help give me a call.with that low of mileage the stock exhaust should come out really easy.
Old 06-23-2011, 02:47 AM
colospgsTA's Avatar
Not that I have any big work done myself, but if I started over with $2000 I would do headers, y pipe, and hooker/magnaflow (what I have now-cheap, sounds great!) exhaust. Save the LS6 intake, get 4.10 gears, Lou's Short Stick, sub-frame connectors, and a mail order tune!
Old 06-23-2011, 05:53 AM
if its ok leave it but its a good upgrade.
Old 06-23-2011, 06:01 AM
MonmouthCtyLS7's Avatar
Headers, Lid, Catback, LS6 intake/PTB, mail order tune is a good start
Old 06-23-2011, 07:14 AM
BLKZ28VERT's Avatar
I am fairly new to this, so forgive me if this is a stupid question............but why change the motor mounts to poly motor mounts? Is there something wrong with the stock ones.
Old 06-23-2011, 05:33 PM
zracer323's Avatar
Nothing wrong with the stock ones, but some people have trouble with their y-pipe banging the floor board and poly mounts will help alleviate that.
Old 06-23-2011, 06:09 PM
cpo
cpo's Avatar
Other than a mail order tune, lid, and an axle-back exhaust, I'd put the money in the interior (seats, shifter, audio) and stiffen-up that convertible chassis as best as possible.
Old 06-24-2011, 11:21 AM
udienow's Avatar
$2000 is not really that much money, esp if you are not doing the work yourself, and you want the best parts. Good headers and a cat-back can easily cost $2000+ on their own... I know my system did (luckly it came with the car). I have ARH LTs with a catted Y, Magnaflow quad tip cat-back, and an e-cutout. Easily over $2000 in parts alone.
Old 06-24-2011, 12:43 PM
Nando92's Avatar
If you want the best of everything i suggest you save the 2k and wait till you have like 5k or more.
If you really want to get something done now i would just go with an SLP lid, smooth bellows, and a Catted Y.
I would leave the internals alone until you have more money.
Old 06-25-2011, 04:44 PM
geoffreymexico's Avatar
If you are going with the best of everything route you can easily spend that on just the headers, ory, and catback.
I would prolly do that and then start saving for an intake, clutch, rearend, and then a heads/cam combo.
