newb needs help
newb needs help
i have a 5.7ls1 with th350. i bought the motor from a friend of mine. he had the motor in his 95 240sx, but he has decided to go with a 6.0. he kept all of the accessories off the front of the motor along with the intake, injectors and wiring harness ect. i have all of the accessories off of a lq9, CAN I USE ANY OF THIS STUFF IN MY 94 CAMARO SHELL? WHAT ARE THE MAJOR DIFFERENCES IN THE TWO SETUPS LS1 VS 6.0.
I AM RUNNING THE EDELBROCK/ MSD CARB. SETUP SO INTAKE AND HARNESS ARE NO PROBLEM.
THANK YOU
THANK YOU
I am just guessing here but I am pretty sure allot of that stuff should work because the blocks are similar, but I would look up the diagrams of both the ls1 and the 6.0 and see if they are the same. Sounds like a fun swap, good luck.
