About to do a ton to my f-body, any additional suggestions?
This weekend there were some insane sales going on so I ordered a ton of stuff for my '98 z28, here's what I'm going to have someone do but I was wondering if there's anything else I should do at the time. I've seen on LS1Tech people recommend doing motor mounts, spark plugs, flexplate, and wires while doing this stuff. Thoughts on that?
This is what I have coming in the mail:
Pacesetter long tubes
Texas speed off road Y-pipe
Texas speed rumbler cat back
Yank SS 3600 stall converter
Big trans cooler
UMI:
- 3 point weld in subframe connectors,
- crossmember mounted torque arm w/ driveshaft loop,
- weld in LCA relocation brackets,
- on car adjustable panhard bar & lower control arms
So are spark plugs, wires, flexplate, and poly motor mounts somethings I should do? The car has 137k on it (I know that's a lot but the car was babied and maintained very well)
Anything else I should do while all that other stuff is being done?
Thanks.
Big trans cooler
UMI:
Thanks.
Motor mounts are a lot easier to do with the manifolds/headers out of the way...definitely something to do while you're in there if you can. Plugs and wires are definitely a good maintenance item if the ones on the car are old. Can't really say about the flexplate, though.
LS1Tech Administrator
Received 1,489 Likes
I would not worry about the flex plate on a '98-'00 car, for an application like yours. The '01+ stock plate is weaker, but you have the better one which should be fine for your setup.
Thanks for the input, Element.
I've already got 15" prostars with MT ET streets ready to go on the car once all these parts go on 10" wide wheels in the back, 6" up front. 10.5" wide tire out back.
Thanks for the input!
Yeah I knew going into the order that it'd be super loud, but FWIW, the car will only be cruising at night or going to the track. It's not my DD.
see above
see above
I hope your doing all this stuff yourself, a shop would have a field day with your wallet. Lol. You dont happen to live close to fairfield, ca do you? I do installs/welding as a side job.
I've thought of buying a cheap high mileage z28 and buying this stuff for it...
Suspension
$130 UMI panhard rod (on car adjustable)
$180 UMI Lower control arms (on car adjustable)
$60 UMI Lower Control Arm Relocation Brackets (weld in)
$440 UMI Torque Arm/ Drive Shaft Loop (tunnel mount)
$280 UMI Sub Frame Connectors (weld in)
$600 Rear QA1 Double adjustable drag shocks
$470 Front QA1 drag springs (275lbs) and Front adjustable Shocks
$2160 Sub Total
Driveline
$300 3.73 gears
$75 Tranny cooler
$700 Stall (4000rpm)
$480 Junk yard Wheels/ Hoosier or Mickey DR's (255's)
$1555 Sub Total
Power
$255 UD Pulley w/ belts and new bolt
$200 FTRA
$100 Lid
$65 Ported Throttle Body
$300 LS6 Intake
$600 Texas Speed 228r 112LSA Cam Package w/ (Springs, pushrods, retainers)
$165 Texas Speed ported LS6 Oil Pump
$40 LS2 Timing Chain
$330 36lb Fuel Injectors
$62 Poly Motor Mounts
$370 Pacesetter Painted Headers and ORY
$20 TR6 Spark Plugs
$50 Manual Cut out
$500 Dyno Tune
$3057 Sub Total
Safety
$575 Wolfe 6 point roll bar
$575
Parts Total
$7,347
Nice 11 sec. car
Suspension
$2160 Sub Total
Driveline
$300 3.73 gears
$75 Tranny cooler
$1555 Sub Total
Power
$200 FTRA
$100 Lid
$300 LS6 Intake
$20 TR6 Spark Plugs
$50 Manual Cut out
$500 Dyno Tune
$3057 Sub Total
Safety
$575
Parts Total
$7,347
Nice 11 sec. car
Suspension
$2160 Sub Total
Driveline
$300 3.73 gears
$75 Tranny cooler
$1555 Sub Total
Power
$200 FTRA
$100 Lid
$300 LS6 Intake
$20 TR6 Spark Plugs
$50 Manual Cut out
$500 Dyno Tune
$3057 Sub Total
Safety
$575
Parts Total
$7,347
Nice 11 sec. car
Suspension
$2160 Sub Total
Driveline
$300 3.73 gears
$75 Tranny cooler
$1555 Sub Total
Power
$200 FTRA
$100 Lid
$300 LS6 Intake
$20 TR6 Spark Plugs
$50 Manual Cut out
$500 Dyno Tune
$3057 Sub Total
Safety
$575
Parts Total
$7,347
Nice 11 sec. car
I'm going to be having a shop do the work. I'm in metro Detroit so there are plenty to choose from and the pricing is very competitive. Plus, the labor on a LOT of this stuff overlaps which is why I'm doing all of this.
