Frost Shift Light
Old 07-14-2011, 10:11 AM
LS1T56FTW's Avatar
Default Frost Shift Light
I currently have the power and ground ran for my Frost shift light. I would like to get the signal from a coil, rather than the PCM (just my preference). Anyone have any pictures of what wire they got the signal from? That would make my life a lot easier. Thanks!
Old 07-16-2011, 03:33 PM
LS1T56FTW's Avatar
Bump. Someone has to have something!
Old 07-16-2011, 03:38 PM
Black96z28's Avatar
it would be a lot easier to use the tach signal from the pcm. why is it that you don't want to? Besides, you would have to wire it to get pulses from all 8 coils to make the light work correctly.
Old 07-16-2011, 04:27 PM
RsSean's Avatar
You can tap into the coil harness off the right side bank. If you call Nitro dave they will tell you the correct wire to tap into off the coil connector.
