160 degree thermostat question
Old 07-26-2011, 05:56 PM
jt_2002_ta's Avatar
Default 160 degree thermostat question
i bought a 160 deg stat and just wondering if any computer mods are needed to control fans
Old 07-26-2011, 06:14 PM
ULTIMATEORANGESS's Avatar
Smile
i would get it tuned.
Old 07-26-2011, 06:22 PM
jt_2002_ta's Avatar
will it cause any problems untuned
Old 07-26-2011, 07:26 PM
Smile
NOT SURE. IM SURE ITLL AFFECT afr THOUGH.
Old 07-26-2011, 08:43 PM
Kurt D's Avatar
It won't hurt but it won't help either, unless the car is at speed.
Old 07-26-2011, 08:48 PM
WS9 Formula's Avatar
u need to get the fans reprogrammed to turn on at the cooler stat temp.
Old 07-26-2011, 09:18 PM
nick2334's Avatar
when i put a 160 in mine it ran fine just the fans did not kick on when they should shortly after that i got my car tuned
Old 07-26-2011, 09:27 PM
sjsingle1's Avatar
just do it.......you can......but dont have to get a tune for it.......nuff sed
Old 07-26-2011, 11:04 PM
WhiteKnight '01's Avatar
Is there any benefit to running a 160* stat? Are they any cons?
I thought I had read that you need some of that engine heat up and around 200 to keep the engine oil thin and lubricant, and if it gets too much cooler it will affect HP and fuel economy, etc.
Old 07-27-2011, 12:54 PM
sjsingle1's Avatar
LIES LIES...ALL LIES.......git r dun
Old 07-27-2011, 02:06 PM
CarGuy1's Avatar
True and It's Overrated, but most who have already changed to cooler thermostat don't want to hear it...
The higher temps also aids in burning-off any moisture / condensation and some contaminates build-up and lowering temp only hurts the engine in most cases unless you live in the desert. The engines are designed to run at 200 deg. temp. in most cases, so unless you're racing and have a tune to make the most of the HP increase, it won't be much of a benefit.
