Coolant bypass or not
Hey everyone,
I am debating doing a coolant bypass because it is quick and easy but I am not sure if it is the smartest idea because my car is a DD and will see some sub 0 degree days in Chicago. My friend showed me this link (http://www.ws6.com/mod-8.htm) and the modification seemed to have more than an effect that I expected. I know it is on an LT1, but still it was a noticeable gain. Any thoughts?
Internet Mechanic
Those results like stated was with a whole different motor, and too many varibles to compare. Also the "increase" to be honest is neglible. Most do it since some aftermarket intakes like a FAST are designed with out it.
The thought is why introduce any more heat then needed. I have started my car in -20 degree days and it sat outside. No icing of the TB. MAYBE for someone in Canada.... maybe.
My Trans Am is the only car I've had with a throttle body "hot" coolant line going through it. Just about everything else I've owned was run in sub-10F weather, and they never had any issues.
I think GM designed a solution for a problem that never really existed with the throttle body coolant throughput.
mine a dd and i did it just because when it comes to incoming air cooler is better! However i realize in md im not seeing temps that low.
Pontiacerator
I did it on my 01 TA when I had the TB out to be P&P'd. I usually only drove that car on nice days. But one very cold day the car was parked outside and after starting it, I had a strange driveability issue, really rough running. It cleared up after a block or two of driving.
I don't know that it was TB icing, but it was enough to make me leery about doing it on my other cars.
I've seen a few other car with it but don't really see a point in it. IF you do it just search on here for what you need and go to a parts store and buy a few clamps and a piece of hose for 2-3 dollars. Its not worth it if you pay 15 dollars for a kit
