ls1 upgrades
Old 08-17-2011, 03:30 AM
LuiS15700's Avatar
Default ls1 upgrades
im a owner of a 98 ss 6 speed, and i was wondering if with mild cam, intake,throttle body,headers, underdrive pulley, could i achieve 380 to maybe 400 hp at the wheel, and if not, whats the best approach without too much internal work, i have also been considering turbos, and how would i be able to boost stock???? anything will help greatly thank you!!!
Old 08-17-2011, 08:35 AM
LeanPocket's Avatar
if u get a cam.. your going to require alot of other things: Complimentary heads, hardened push rods, lifters, intake + matching tb (up for debate), lid, LT's, shorty mid pipe ( orx or ory w/ cutout ) catback, beefed up rear end.. and ofcourse a GOOD tune.. id also consider motor mounts..
I wouldnt use a udp.. but thats jus me.. or boost it without any internal work done.. but thats just me
others will chime in with better opinions
Old 08-17-2011, 09:33 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
^ what he said.
Old 08-17-2011, 09:42 AM
projectX's Avatar
I say a 228-230 cam with those mods you have listed with a tune and your around 375-380. (I'm sure you know with a cam swap your gonna wanna upgrade valve springs etc) If you want 400rwhp or more just go with heads too other-wise a moderate to extreme cam will get you close if not there alone with supporting mods.
Old 08-17-2011, 10:22 AM
Ya you won't see 400ish w/ a mild cam unless you have heads to go with it and supporting mods.
Old 08-17-2011, 10:42 AM
LeanPocket's Avatar
exactly ^^
of if ur real cheap.. 250 shot nawz u should see 400 hp
Old 08-17-2011, 12:11 PM
LuiS15700's Avatar
So with the mods that I posted, how much can expect?? And im also thinking of gears, what would be a vood set up
Old 08-17-2011, 12:46 PM
Troy5061's Avatar
All depends on the tune and what kind of condition the engine is in. A 228 cam like mentioned above should get you in the 380whp range with all the supporting mods. If you want 400whp you will probably need a bigger cam, not saying it hasn't been done but it's not as easy. For 400whp cam only personally I would go with a TSP Torquer V2 or call Geoff at EPS and see what he recommends.
Old 08-17-2011, 12:59 PM
NC98Z's Avatar
He isn't going to make it to 400rwhp with just a cam and supporting mods unless one of the mods is a set of heads. Seeing how your about bone stock have you looked at a Procharger setup. You could reach your goal without any internal mods.
Old 08-17-2011, 01:00 PM
Think you already have 3.73s? I would stick with those until your ready to invest in a 12 bolt or 9" to change gears.
Old 08-17-2011, 01:07 PM
LS-ONE_DAY's Avatar
My plan as far as power gaining mods only - long tube headers, y-pipe, catback, lid, throttle body, intake manifold, cam - something like a TSP 224R or 228R, that should get me pretty close to my goal of 375rwhp but I'm in an A4 so I might not quite make that.
Including other work I'm hoping to run mid 12's with that setup
Old 08-17-2011, 01:14 PM
^ thats my exact plan, already have the catback and lid, but still along way to go
Old 08-17-2011, 01:40 PM
LeanPocket's Avatar
yo if u want to grenade your engine try that setup u posted
if u want to add a camshaft to your car you need supporting mods, like i listed above
https://ls1tech.com/forums/new-ls1-o...anna-fast.html
^^ this gives u an idea of what you need in order to reach good rwhp goals
through my experience, full exhaust + lid is a great start w/ a tune, then you can add ur gears, followed by a beefy rear end.. i'd do all of this before you do a heads/cam setup.. remember u need supporting mods AND complimentary heads.. or else your engine wont handle an idle properly and never make any power throughout ur power band.
if u want gears, and ur a m6, 4.10 is a good choice. I have 3.73 and its a noticeable difference
Old 08-17-2011, 01:42 PM
LeanPocket's Avatar
get a stall
Old 08-17-2011, 01:45 PM
I'm def copping a 3600 stall after bolt ons.
Old 08-17-2011, 03:13 PM
garygnu's Avatar
full mods and a 224/228r cam pkg should make 375,who will tune it.do you have a stock clutch?you will need better rod bolts if you want to boost it.some used 243/799 heads ($400) with tr224 or EPS 222/226 cam can make close to 400.you will need a ls6 intake($300) with a ported TB($70),and a good cold air intake (cai).check out TSP,thunder racing ,or the ws6 store to start.ask alot questions before you buy any thing.
Old 08-17-2011, 03:22 PM
JohnS Z28's Avatar
heres my budget build which i can start hopefully this spring when my baby comes out of storage.
Pacesetter 1.75"-$400
Custom off road X- $250ish
ls6 intake-$300-$400
243/799 heads, $400, $300 if your lucky
Undecided cam, will be talking to texas speed. $600
tune-$400?
This should defiantly put you into low 400's, no heads, 370sh
Its goanna be about $2500 for a nice street build, $3000 if you add some various supporting mods.
Old 08-18-2011, 01:44 AM
LuiS15700's Avatar
okk so what the best overall approach, i would like to make around 380-400 whp, i think anything after that is too much for the street( all that power, cant really use it, i use the car frequently, dont want to make it into a project)
Old 08-18-2011, 06:02 AM
LS-ONE_DAY's Avatar
Originally Posted by LeanPocket
get a stall
Well if you read my post I listed power gain mods only I'd be getting some variant of Circle D converter in the 3000-3600 range. For my application I might start small, like a 3200ish and then re-stall it to 3600+ after the cam.
Old 08-18-2011, 07:53 AM
Troy5061's Avatar
Not quite 400 but damn close.
https://ls1tech.com/forums/dynamomet...o-numbers.html
Quick Reply: ls1 upgrades
