Is an 05 LS2 and 02+ LS6 cam the same?
Old 09-01-2011, 06:02 PM
Ratical's Avatar
Default Is an 05 LS2 and 02+ LS6 cam the same?
Just wondering is they are the same cam and if they interchange.
Old 09-01-2011, 06:26 PM
cali_bear2003's Avatar
I could be wrong, but I believe the LS2 had the same cam as the 2001 z06.
Old 09-01-2011, 08:11 PM
Ratical's Avatar
I know they have different part numbers, but I thought I heard they were basically the same grind.
Old 09-02-2011, 01:17 AM
usafws6's Avatar
no there not, the ls2 cam is smaller. if you put an ls6 cam in an ls2 it would probably make more the 400 horses
Old 09-02-2011, 05:57 AM
Ratical's Avatar
Oh ok. Thank you for the info. I guess I will pass on the LS2 cam.
Old 09-02-2011, 06:06 AM
omarrakeen's Avatar
ls6 and ls2 cams have same specs. but i dont think they are interchangeable, one has 3 bolts the other doesnt. also the LS2 has different knock sensor or position sensor as well. if you are going thru the trouble just pick a slightly larger or better performing cam. ls2 or ls6 cam isnt worth the trouble.
Quick Reply: Is an 05 LS2 and 02+ LS6 cam the same?
