Best 02 Sensor for long tube headers??
What are some of the best 02 sensors that work best and last long for a cammed Camaro with longtube headers?
Im hearing alot about AC Delco and Bosch what is yalls feed back??
Thanks
Thanks
Moderator
If you think any particular sensor is going to be trouble
free and need no codes killed and so on, you'll end up
disappointed. I ran the NGK 'vette rear ones for a long
time and they worked but had some obvious heat
shortage, same is going to be true for the others. It
might help to work on the thermal problem more than
worry about brand. There's only so much heater power
to throw and only so much sensor surface to soot up
before they crap out.
Most guys will recommend denso corvette rears for a 2000 vette if you're searching for part numbers. The Bosch 13111 have mixed reviews for some reason. I haven't had any problems with them but would do with denso's if I had to do it again and had time to get them.
i have to hold out on which ones to use.i've been thru 2 sets of ac/delco's and they keep
throwin lights and switchin problem's.using bosch right now to soon to tell.
9/15/11...BOSCH fixed my problems i found that i have to run the old style thimble
head style to have them work right in my hookers...any with new pencil type with
hloes fall short...any comments on why?
