Took off by mistake, AC Condenser
Internet Mechanic
Aww man that sucks. i will tell you back in the day... like 2001 I did that with my first car. Thank god I was planning on removing the A/C anyways but it was just too funny.
Take it to a certified place as since the seal has been broken, they may need to re seal before re pressurizing.
I would normally quote USA rates but looks like your vehicles is in Germany?? So I would just call around.
Here in the US you can go to any parts store or better yet Wal-mart and buy what you need to refill it. I bought a kit at the beginning of this summer that had 3 cans of refrigerant with oil mixed in a can tap with gage and a how to DVD for $40, it was a awsome deal because that much refrigerant and oil would cost $45.
You need to take the car to someone (shop) that can pull a vacuum on the system with a vacuum pump then refill it. Once you open the system to the atmosphere it must be vacuumed down to remove the moisture from the system before you charge it otherwise you will have problems with it freezing up.
If your looking for a vacuum pump check harbor freight tools. You can get one on sale usually.
Seal off your remaining AC system. The accumulator has a desiccant bag in it that will absorb atmospheric moisture, and it can go bad in as little as a day if you live someplace humid. If yours has been exposed for more than a day or two, I suggest you replace it. They're not expensive (I think the one for my car was $50). Add two ounces of PAG oil directly to the accumulator before you re-install it, then seal the system up and take it to have it vacuumed out and recharged. The low side port will get replaced with the accumulator, but I also suggest you take the hi-side line with you to the auto parts store. They'll replace the schrader valve for like $5. It's really cheap, and should be done. Those ports are common leak points and are easily damaged... it's so cheap to replace you should have it done. The NAPA guys will swap it out for you using a special tool.
