Headers and Borla
Old 10-18-2011, 04:49 PM
Count of Monte Crlo's Avatar
Default Headers and Borla
I have a basically stock 99 Z28. After a lot of searching I cannot find the answer to this question and it is a pretty noob question. I've been thinking about headers. Most people seem to prefer BBK or Pacesetter LTs. Are these compatible with a Borla catback which my car already has? What do I need to make it work? Will they give me a check engine light? Thank you for your help.
Old 10-18-2011, 06:39 PM
SOMbitch's Avatar
It will throw a bad cat code unless you get it tuned out of the pcm. You need to get a Y pipe to match your headers and yes it will work fine with the Borla though it may or may not require "minor" fabbing to fit...
Old 10-18-2011, 06:50 PM
RedRocketZ28's Avatar
Just installed BBK LT's two weeks ago on my Dad's 98 SS with Borla non-adjustable catback. Everything fit perfect.
Old 10-18-2011, 07:22 PM
LS-ONE_DAY's Avatar
I have the Borla adjustable system on my 99 Formula. I just ordered ARH 1-7/8 headers and 3" Y, waiting to receive them. Should go on without an issue. Most Y pipes will match up to all catbacks depending on diameter of them. Check that first.
Old 10-18-2011, 08:25 PM
LS1WS6dreamer's Avatar
I had to have my merge to I-pipe welded up. The OD of the BBK was slightly larger than the Borla I-pipe. I couldn't pull the Borla I-pipe out to really try fitting them together, but it looked to me like they wouldn't fit. Tried a band clamp and it leaked. Had a muffler shop weld it up and looking at it now i've decided the band clamp was indeed a "crackpipe dream" lol
Cost me like $20 hell I wasted $12 on the bandclamp.
BBK install went great!
yes you will get codes. EGR, AIR, rear 02's. Sent my PCM off to frost. Easily worth it.
Old 10-18-2011, 08:29 PM
t5munoz's Avatar
I would say go with the American Racing Headers oh yea!!!
Old 10-18-2011, 09:18 PM
973800CamaroRS's Avatar
Texas speed has some nice headers you should check them out
Old 10-18-2011, 10:37 PM
I have an electric cutout just about under the rear seat, will it interfere with anything as far as the y pipe that comes with the BBK fitting to the Borla? Also if it throws codes unless tunes, will it essentially run like crap unless tuned? How much would an average tune cost to correct the codes? Thanks
Old 10-18-2011, 10:59 PM
theguyulove2hate's Avatar
I have never installed the BBK headers, but I know the pacesetters are good. Every set I have installed go in with out a problem. I know the pacesetter y-pipes will go on to you Borla with out a problem as well. That set up sounds really good, almost as good as my old GMMG set up.
If you cant find any one to tune your codes out for cheap, if you want you can mail me you pcm and I can do it for you. I have 99 unlocked so it would just be the shipping.
Old 10-20-2011, 10:39 AM
Thanks for the offer, but its my daily so I can't afford the downtime. What are your guys best estimates for what a shop should charge for a header install? and a tune somewhere? I assume there will have to be some welding from the header and y pipe to my borla set up so is it better to use a generic exhaust shop or my regular mechanic if they will do it? I am not sure if any of the LS1 performance shops are still in central florida, I know Mike Norris was the best but my understanding is that he left. Thanks for the help.
Old 10-21-2011, 10:59 PM
any reasonable install quotes from guys that have gone to shops for this? (I know most if you guys have done it yourselves, but I am not in a position to do that)
Old 10-22-2011, 08:58 AM
LS-ONE_DAY's Avatar
Depends on what kind of cars the shop usually works on. I got quotes anywhere from $600 to $950 (<-- they work with high end cars). Never asked a plain old mechanic to install them. I'm just doing it myself with a friend or 2 in a couple weeks
Old 10-22-2011, 10:00 AM
flintwrench69's Avatar
Damn that sounds pretty high. If I had to guess I would say its about a 4-5 hr job so $400 sounds about right.
Old 10-22-2011, 10:16 AM
LS-ONE_DAY's Avatar
Most places quote it as a 6-8 hour job.
Depending on the brand of header installs can get complicated. Some you have to modify the K member to get them to fit too. BBK, Pacesetter, and ARH are pretty good about not having any install issues, Kooks as well I assume.
Old 10-22-2011, 10:19 AM
usafws6's Avatar
Were do you live? I do the install for 300
Old 10-22-2011, 10:24 AM
usafws6's Avatar
O nvmi see you live in florida. Try to find a local on this board that knows what theyre doing. Mechanics will try to suck every penny they can out of you.
Old 10-22-2011, 11:24 AM
alright, is a tune after headers absolutely necessary? In other words, will the car run like crap unless one is done?
Old 10-22-2011, 01:56 PM
SM105K's Avatar
I would check out the ebay stainless headers. They are cheap and are Kooks knock offs.
