2002 pontiac ws6
Old 10-27-2011, 06:58 PM
burn rubber's Avatar
Default 2002 pontiac ws6
hi, looking to purchase a 2002 pont ta ram air ws6 car. how do know if its a real ram air ws6 car? i have the vin number if that helps. thanks for any input
Old 10-27-2011, 10:01 PM
usafws6's Avatar
Check the numbers on the door i forget the ws6 code
Old 10-28-2011, 12:01 AM
SM105K's Avatar
The code for WS6 is...........WS6.
WS9 + Y82 + WS6 = Trans Am WS6
Old 10-28-2011, 12:06 AM
SREETRACEGUY's Avatar
pop the hood and if the hood is functional then its real if its not its not. also the ws6 airbox sits up higher than a normal trans am formula or camaro so it can suck more air
Old 10-28-2011, 10:55 AM
NY02ws6's Avatar
^^ this does not tell you if its a REAL ram air ws6, it only tells you if someone took the time to swap a hood, happened to a buddy of mine a couple years ago...only way to know for sure is check the door sticker, and yes as someone else already said the build code for a real ws6 is ws6 lol
