ls1 cam, stall, and headers.
Old 11-26-2011, 02:27 PM
fixitpro's Avatar
Default ls1 cam, stall, and headers.
First ill give some info on my car. It is a 2000 camaro auto, ls1, NON ttop car. It is a z28 not a b4c car. I live in Sedalia, MO. 65301
What cam can I use in a stock ls1 motor without doing ANYTHING else?
Like a nice sound and more performance.
wanting something in the range of a 3200 stall.
This is a everyday driver. Only 1 mile from my job. I am a true newbee so I dont know if i need a lockup or non lockup converter. I dont want to have to get up to 3200 rpms at every stop light.
Need some cheap header also.
Would be interested in getting these parts used. or if you could give me the part numbers to cheap parts that would work, That would be great too. I would prefer to hear from people that have used the parts before. Dont have the money or time for trial and error... Thanks in advance for all the help guys...
msktlk@iland.net
(MSKTLK)
Old 11-26-2011, 04:09 PM
TImmy_Jones's Avatar
eBay headers, TSP True Duals, 224r cam (going to require a bit more work than just putting in the cam), 3600 stall.
Also, buy a nice roadbike, no sense in driving the car 1 mile each way, poor thing never even gets warmed up.
Old 11-26-2011, 05:43 PM
ULTIMATEORANGESS's Avatar
Smile
you can get away with a 3200 and still be very streetable.
my triple disc 3600 feels like stock.
Old 11-26-2011, 05:46 PM
02ws.sik's Avatar
^ what brand and with a stall does it only work with the brake held in?
Old 11-26-2011, 06:27 PM
Smile
vigilante.
it works like a stock converter just better lol.
Old 11-26-2011, 06:47 PM
02ws.sik's Avatar
So it always shoots off at 3600 rpms or only under some gas?
Old 11-26-2011, 07:19 PM
fixitpro's Avatar
"Going to require a bit more work than putting in the cam" is little more cam than I think I am looking for? And if I had to use a bike to get to work, It wouldnt be worth having a car for me. Nice sounding car is a part of my motivation to work. And yea I want to be able to back up the nice sound. But im not looking to get in the 10 sec club yet. Just dont want to be in the 14 second club. Ha Ha 99% of this cars use will be street. Plus you can have some fun in a mile. Some people spend alot more money to build a car to only go 1/4 of a mile.
I took my car to every place in town and tried to get them to put duels on it and they wont do it. For now I just want to do the mods I mentioned then go from there. Im even going to throw the 4:10 gears in and c how long the 10 bolt holds up. Ha Ha. I have a set of pro stars with slicks but I dont plan on breaking them out till I get further along in the project. ie: 12 bolt, and alot more power (turbo or SC, heads etc..) Not looking to put a blower cam in now.
But for now just want to change the cam, add a stall, and maybe headers and fix what breaks.
I am greatful for your help, Just think maybe your looking past my current goals. Slow down a little for me. Ha Ha
Old 11-26-2011, 07:45 PM
fixitpro's Avatar
Originally Posted by ULTIMATEORANGESS
vigilante.
I cant find anything made by vigilante on ebay?
tried looking up the 224r cam too. This searching around for stuff sucks. This is where I usualy throw in the towel and go play COD MW3. Ha ha
Old 11-26-2011, 09:58 PM
Smile
look under precision industries.
but it feels like stock. no extra pedal effort is needed to get my car moving.
Old 11-26-2011, 10:09 PM
Xaviarrahl's Avatar
Good question about the cam. Would be nice to know how much lift is possible work factory springs, and how much lift/duration before piston to valve clearance becomes an issue without extra relief in the piston
Old 11-26-2011, 10:39 PM
02ws.sik's Avatar
I know ms3 you have to change springs and i prettty sure valve clearance isn't an issue
Old 11-26-2011, 10:50 PM
even with an ls6 cam a spring upgrade is required.
dont go mild with a cam. youll regret it.
Old 11-26-2011, 11:07 PM
02ws.sik's Avatar
Go big or go home!
Old 11-27-2011, 09:17 AM
zracer323's Avatar
Any cam swap worth doing requires new springs. Changing a cam without doing pushrods as well is not recommended.
Old 11-27-2011, 09:53 AM
evilz99's Avatar
hope you also know that the prostars you have will not bolt up in the back without some "GRINDING" of the calipers. but ask these other guys too because I am a newbie too so not 100% positive. Also I have been looking into cams too and it seems like the 228R (according to other people on here and the sounds clips I heard) is a great cam. BUT, while your doing the cam you MUST do valve springs, REALLY SHOULD do pushrods, AND should also do timing chain and oil pump. sorry dude it was bad news to me too. seems like a lot but I have been assured that it is way worth it!.
Old 11-27-2011, 10:29 AM
Fry_'s Avatar
It sounds like your on a budget and trying to do alot of mods for cheap, and that will only lead to head aches. A cam swap isn't cheap.
cam-$400
springs-$180
push rods-$110
bolt&gasket kit-$58
+tune-$400
$1148
and those are the bare minimum parts that you have to get to put in a mild cam, a big cam will require better springs and push rods. Then there are the parts you really should replace at the same time.
LS2 timing set-$110
ported LS6 oil pump-$180
+valve seals-$28
$318
then add an oil change, antifreeze, balancer installer, and other random stuff that you end up buying on a job this size and your easily to $1550-1600 to do the job right. But before you do the cam you need a 3200-3600 stall converter, headers, y-pipe and catback, or true duals.
The saying goes. Fast, cheap, reliable, you can only pick two.
Old 11-27-2011, 11:28 AM
02ws.sik's Avatar
Its a worth it if you have the money imo sounds bad a$$ too.
Old 11-27-2011, 11:30 AM
02ws.sik's Avatar
You dont have to have a stall first it just will be the same from a dig till you hit say 3500.
Old 11-27-2011, 07:25 PM
fixitpro's Avatar
cam-$400
springs-$180
push rods-$110
bolt&gasket kit-$58
+tune-$400
$1148
LS2 timing set-$110
+valve seals-$28
$318
Sounds good. $1500. is where I want to be. You got any part numbers to go with those figures? I go way over budget when I start looking for parts and end up looking for a ls2 out of a gto. Ha Ha. Wish someone threw all these parts you listed on ebay with a buy it now. Ha.
Old 11-27-2011, 07:33 PM
fixitpro's Avatar
Car came with the pro star rims on it. Slicks in the back and skinies on the front. Instead of grinding on the calipers you can get spacers behind the pro stars. Also came with vette wheels. Im running the vette wheels due to the car does not have much power now. 14:05 in the 1/4. but it has sucky gears. 2:92's. Like I said I have some 4:10's for it. The slicks have threads showing and the front tires in bad shape too. I will just get some cheater slicks for the vette wheels. Doubt I use the pro stars in the near future.
Quick Reply: ls1 cam, stall, and headers.
